Zonda_ 0 Posted June 18, 2007 Report Share Posted June 18, 2007 Drivers side rear is open and won't respond to either of the switches or the total closure on the key fob. All the other windows are working fine. Is there some way I can crank it up manually? Link to post Share on other sites
Karr-Man 0 Posted June 18, 2007 Report Share Posted June 18, 2007 i dont think u can do that without removing the motor from the regulator, and u need to take out the whole assembly to remove it.if u r desperate its possible to wedge the window glass in the closed position using a block of wood the correct size inside the door.also u might wanna pull back the rubber sleeve from the wiring by the door hinge and see if the problem is just a broken wire. Link to post Share on other sites
SiGainey 1 Posted June 19, 2007 Report Share Posted June 19, 2007 binbag over it / find a garage to park in? Link to post Share on other sites
cadguy77 0 Posted June 19, 2007 Report Share Posted June 19, 2007 yeah check wire in rubber by the door hinge, my drivers one done similar and it was the wire getting crimpped when the door closed.If all other windows closed when you hold the key in the door in the close position the the window motor is probably not getting power Link to post Share on other sites
Donkey_Punch 0 Posted June 19, 2007 Report Share Posted June 19, 2007 i had same problem, the window cable had a kink in which caused stress on the motor, and eventualy burnt it out. to resolve i had the door card off ... (dead easy pops on and off) and then undid the window from the lifting arms (2 bolts) placed a peice of wood under the window to keep it up and put in 2 wedges to stop it rattling and possibly falling down again, then got one ordered from a breakers yard for £30 inc vat. took me about 3 hours total from start to finish, Link to post Share on other sites
petervr6 0 Posted June 19, 2007 Report Share Posted June 19, 2007 yep me to had a broken wire behind the rubber. but mine is 5dr and by the looks every body else`s is also 5dr is yours 3dr or 5dr Link to post Share on other sites
descb600f 0 Posted June 19, 2007 Report Share Posted June 19, 2007 Could be that the glass has come off the rubber guide and the mechanism is going up and down without the glass can you hear the mechanism working Link to post Share on other sites
Zonda_ 0 Posted June 19, 2007 Author Report Share Posted June 19, 2007 It's a Vento, slid the rubber back and there is a red wire snapped clean in two. Managed to drag the window up by hand so have to try and fix the wire somehow. Link to post Share on other sites
cadguy77 0 Posted June 19, 2007 Report Share Posted June 19, 2007 get that wire fixed, cased solved i reckon Link to post Share on other sites
