descb600f 0 Posted June 8, 2007 Report Share Posted June 8, 2007 Hi Need to replace the steering rack I have the new one here just not sure if i need to drop the sub frame to get it out has any one done this??Not liking the look of the bolts holding it in but cant see another way of doing it. Link to post Share on other sites
descb600f 0 Posted June 10, 2007 Author Report Share Posted June 10, 2007 Well job done wasn't too bad but did involve dropping the sub frame.What a B****** to get that back on.Not bad considering I was just investigating the knocking before doing the chains.Well that will be for another week Link to post Share on other sites
ingham 5 Posted June 10, 2007 Report Share Posted June 10, 2007 if you dropped the subframe then you should replace the bolts ,vw says not to refit old ones as they can snap Link to post Share on other sites
VR6Rich 3 Posted June 10, 2007 Report Share Posted June 10, 2007 What did the knocking turn out to be in the end? Link to post Share on other sites
descb600f 0 Posted June 11, 2007 Author Report Share Posted June 11, 2007 Had some play in the rack stood underneath while it was on the rack it was coming from the near side of the rack.I still have a very slight knocking at v low speed but the bearing, droplink and ball joint all seem to be ok Link to post Share on other sites
VR6Pete 1,455 Posted June 11, 2007 Report Share Posted June 11, 2007 they are stretch bolts, replace them if you've dropped the subframe as ingham says.got to take my steering rack off, but ive got the advantage of no engine in the way! Link to post Share on other sites
