raceland tuning......
has any one eav brought anything from racland tuning in beligum ... just seen a exhaust main for the vr for £180... and they also have a set of wrx leather recling bucket seats found them on e bay ... are they good bad or has no one tried them yet???
manifolds seem ok got mine. ;)
you really need to wrap it for heat and also look at engiine mounts as there is no flex and this can cause them to crack. There is many a thread on here and dont pay any more than £145 for one..
Good luck!
nice new, not worn out stock mounts should be shweet :) makes more sens buying vibra rather than stock tho if ur gettin new mounts :)
btw there is an alternative to heat wrap , try ceramic coating :) imo is a better option .
Discount on Vibra to premium members dont forget ;)
As said - there will be some movement/flex in the pipe; but not a lot... so in my humble opinion get a set of fast road and that will remove any worries and not be too harsh..
you may get other views from other guys... New is the way forward no matter which ones you go for ;)
