belt slipping like a greased up biffer
Is yours with or without aircon?? have you got the tensioner pulley???
Sounds like you could do with a new belt, if its non ac then don't bother with the one that comes with it, use a good quality 7 ribbed belt.
You can also put some belt dressing on it which will help no end.
Also play about with the tension too.
They don't normall give too much problems till you get over 14psi.
with aircon the stock tensioner is repalced by the charger i think.
i have an extra pulley it needs a new bearing before i get it fitted the belt has about 15k on it i have another 1 im going to try and its VERY tight as it is i dont want it killing the water pump etc
