gav_113 0 Posted November 3, 2006 Report Share Posted November 3, 2006 right my car has always ticked ova at 600 rpm. until this morning it now is at 1200rpm all the time. anyone have any ideas why this has changed? ta Link to post Share on other sites
dellert 0 Posted November 3, 2006 Report Share Posted November 3, 2006 ODB1 or 2? Cos of the Idle Stabilising Valve. You know the next thing you gonna get told................... stick it on VAGCOM!!!!!! Link to post Share on other sites
Russ_vr6 12 Posted November 4, 2006 Report Share Posted November 4, 2006 hey gav! long time no speak! poss vacuum leak mate? Link to post Share on other sites
matth76 1 Posted November 5, 2006 Report Share Posted November 5, 2006 Is it at 1200 revs even when the car is warm? My car starts idling at around 1000-1100 revs when cold but after a minute or two will settle down to 700rpm. Link to post Share on other sites
gav_113 0 Posted November 5, 2006 Author Report Share Posted November 5, 2006 hey gav! long time no speak! poss vacuum leak mate?hey russ!! u still got ur VR? thought u sold it?ticks ova at 1500 when cold, 1200 afta?i un plugged stab valve and plugged it bk in and it was fine again, until i started it up again. so it must be that sticking open or something? Link to post Share on other sites
Russ_vr6 12 Posted November 5, 2006 Report Share Posted November 5, 2006 lol she still 4 sale mate,might not be sellin her tho,check out my thread in members only section il check on a price 4 one 2moz at work if ya like mate?or if ya aboutat all soon u can try mine on ur's and c if it fixes it? Link to post Share on other sites
gav_113 0 Posted November 5, 2006 Author Report Share Posted November 5, 2006 yeah cool!! see if u can get a price mate. sweet! Link to post Share on other sites
Russ_vr6 12 Posted November 5, 2006 Report Share Posted November 5, 2006 no prob mate Link to post Share on other sites
gav_113 0 Posted November 5, 2006 Author Report Share Posted November 5, 2006 tried a different stabiliser valve today but still no change. also changed water temp sensors, and found a broken pin in the main loom plug so i sorted that out! it was no.1 wire on the big twisty plug, not sure where it goes? try and get it on vag-com this week.it is now ticking over at 2000 rpm all the time!! Link to post Share on other sites
Russ_vr6 12 Posted November 5, 2006 Report Share Posted November 5, 2006 i think air leak somewhere mate,il ask the guys @ work 2moz 4 idea's Link to post Share on other sites
Jk* 0 Posted November 5, 2006 Report Share Posted November 5, 2006 Um, i have a leaky breather pipe @ the moment which has meant my car is over fueling and what appears to be idling high. Not as high as yours though. Mine idles between 600rpm and 800rpm though...good luck with it as youll be using as much if not more fuel than me! Link to post Share on other sites
gav_113 0 Posted November 5, 2006 Author Report Share Posted November 5, 2006 just been down da shop, and when i started car every thing was fine again? idling at 600.. came bk from shop and started it up again and bk to 2000!! wot the fuck is going on? its driving me mad!!!! Link to post Share on other sites
dellert 0 Posted November 5, 2006 Report Share Posted November 5, 2006 You checked the accelerator cable? I had one stick once and it used to idle erratic, had to hook the pedal up with my foot to calm it down! Link to post Share on other sites
gav_113 0 Posted November 6, 2006 Author Report Share Posted November 6, 2006 yeah checked that m8.. Link to post Share on other sites
gav_113 0 Posted November 9, 2006 Author Report Share Posted November 9, 2006 right tonite ive found wot the prob is on my car.i thought it was the idle speed valve, so i replaced it, no joy!! checked for air leaks.apparently u should be able to hear the idle speed valve click when u turn ignition on, but mine doesnt, so i connected it straight to the battery and it does? so the problem is the wires going to it? i think one is a permanent live and the other a switchable earth from the ecu? can any one help or got any wiring diagrams?thanks peeps.... Link to post Share on other sites
gav_113 0 Posted November 11, 2006 Author Report Share Posted November 11, 2006 checked the wires from idle speed valve today to the ECU, found nothing wrong with them?? so im thinking it could be to do with the ECU now? ill try my mates 2moz? anyone got any other ideas?? Link to post Share on other sites
Russ_vr6 12 Posted November 12, 2006 Report Share Posted November 12, 2006 one idea mate,try cleaning up all the wiring becausr if any moisture gets in it can do untold damage,we have just replaced half the engine loom at work on a corrado v coz of water,worth checkin? Link to post Share on other sites
gav_113 0 Posted November 12, 2006 Author Report Share Posted November 12, 2006 im going to try my m8s ecu in abit so ill let u know wot happens..... Link to post Share on other sites
gav_113 0 Posted November 12, 2006 Author Report Share Posted November 12, 2006 i just met my m8, and had a look at has vr, i put a volt metre on his idle valve plug and it gave the same reading as mine? so i guess it isnt the ecu?back to the drawing board?? :@ Link to post Share on other sites
gav_113 0 Posted November 14, 2006 Author Report Share Posted November 14, 2006 help still needed pls..anyone got anymore ideas? Link to post Share on other sites
