SankysVR6 1 Posted June 25, 2004 Report Share Posted June 25, 2004 HelpMy V-belt looks all cracked and i wanted to know if anybody had changed it themselves.and how difficult was it, anybody got a guide ?! ?! Link to post Share on other sites
acf8181 0 Posted June 25, 2004 Report Share Posted June 25, 2004 never done it myself, but doubt it'll be that hard. Link to post Share on other sites
FishWick 21 Posted June 25, 2004 Report Share Posted June 25, 2004 Piece of cake.Get a long 8mm bolt (13mm head) from B&Q, needs to be about 4 - 5" long. Looking at the belt tensioner, you'll see a threaded hole. Guess where that bolt goes? Screw it right down until the tension is released from the belt. Then you can take the belt off. They're about £20 from the dealer.You might need to remove the plastic rain shield that shrouds the Power steering pump too. Link to post Share on other sites
six appeal 53 Posted June 25, 2004 Report Share Posted June 25, 2004 Yeh piece of P*ss job for any competant person. Link to post Share on other sites
VR6Steve 0 Posted June 25, 2004 Report Share Posted June 25, 2004 Changed mine myself, so if i can do it anyone can! :-) To make it easier to refit, draw the layout on a sheet of paper before you remove the old one. Link to post Share on other sites
SankysVR6 1 Posted June 28, 2004 Author Report Share Posted June 28, 2004 thanks guys.its probley said before but you folks on here sure know what your talking about. Link to post Share on other sites
SankysVR6 1 Posted July 9, 2004 Author Report Share Posted July 9, 2004 i tried changing this last night but i couldn't get the 8mm bolt in the hole (no jokes). The clips that are holding the fuel line to the fuel rail get in the way.i did try and move the clip out of the way and thought i'll take the fuel hose off to get some more room, but the fuel started dripping out .As I wasn't sure how much fuel would be lost i put it all back to how it was. ?! do i need to remove the hoses or am i doing something wrong.and how much fuel am i going to loose by doing this.any advice please [ Edited Fri Jul 09 2004, 08:18AM ] Link to post Share on other sites
Mangold 0 Posted July 9, 2004 Report Share Posted July 9, 2004 I did mine without removing anything, just get an M8 bolt and wind it in until the tension comes off the belt. If yours is fouling on something maybe you need a longer bolt so the head of it that you turn is well clear of anything. I ended up using a bolt with a large flat bladed screw head. Link to post Share on other sites
VR6Steve 0 Posted July 10, 2004 Report Share Posted July 10, 2004 I too did mine without having to move anything.To confirm, the bolt goes into the top on the belt tensioner, as you look at the engine front left.As suggested above, maybe try another bolt? Link to post Share on other sites
