De-cat............another 20bhp ?
In the title really !
Been browsing the performance VW mag forums and came acroos this subject. Can removing the cat really give you that much more power ? I'm chummy with my MOT man so emmisions aren't a problem !
What do you replace it with ? just a pipe or what ? can you buy the bypass pipes ?
many thanks all
p.s well looking forward to the RR day in Feb. Was hoping to have the beast supercharged by then but the wife has others plans ! x)
Unless you've got forced induction, cat bypass is not worth it - you will actually lose torque low down as there won't be sufficient back pressure.
My car runs a replacement Miltek sports due to the increased gasflow from the s/charger. On the last rolling road, Vince's exhaust vent shot back 8ft when my car hit 6000rpm!! !amazed
Guest couzens
As we r on this subject, if I wanted to have the vsr and rechip done, would I need to replace the standard exhaust system with a larger diameter after-market to aid gas flow or would the standard be efficient?
  • 4 weeks later...
