Corrado ECU running Golf 2.8
Poo, just found out its a 1997 lump, so Im guessing its a coilpack!
My engine is a corrado 1994 ABV.. Dizzy isn't it?
Well, what would happen now, if its even compatible?
If not, can I just put the bottom block(mechanical side of things) in place of the broken corrado bits..
[ Edited Tue Jun 15 2004, 11:50PM ]
94 Corrado ABV engines are coilpack equipped. To run a dizzy on the AAA or ABV, you need the relevant brain, side plate (cam sensor-less one) and of course the dizzy and HT coil, leads etc. And also the requisite cam sprocket on the inlet cam to drive the dizzy.
ABV cams are more aggressive than AAA ones too.
[ Edited Thu Jun 17 2004, 10:23PM ]
