Guest spiked69 Posted September 3, 2006 Report Share Posted September 3, 2006 help have just brought a mocal 13 row oil cooler and kit but dont now how to install it as no no instructions were present.Have a corrado vr6 and i assumed that the fitting kit connects to the oil filter some how but cant see how as it has a large plastic cover over the filter.any help would be fantastic Link to post Share on other sites
Radostormvr6 2 Posted September 3, 2006 Report Share Posted September 3, 2006 You need to fit the sandwich plate on top of the OE water/oil heat exchanger,its next to the oil filter and you should have a longer thread bolt and new end cap.You can get the cap & thread tube from Stealth Link to post Share on other sites
Eat this 2 Posted September 3, 2006 Report Share Posted September 3, 2006 are they any good?do they work on a thermostat? what temp do they turn on at?how much are they etc etc Link to post Share on other sites
mk3anni 0 Posted September 3, 2006 Report Share Posted September 3, 2006 Errr, no.The best thing to do is remove the crappy heat exchanger and run just the oil cooler on its own. Otherwise your making more work for the cooler.Mine runs with a sandwich plate that opens at 86 degrees. Link to post Share on other sites
Petesvw 0 Posted September 4, 2006 Report Share Posted September 4, 2006 Have been wanting to get one meself for a while now!So scrap the standard cooler then steve? Link to post Share on other sites
VR6Rob 0 Posted September 4, 2006 Report Share Posted September 4, 2006 Allways been told to use heat exchanger with a cooler as it helps the oil get upto working temp faster(the water heats up faster and the heat exchanger heats the oil)? Link to post Share on other sites
mk3anni 0 Posted September 4, 2006 Report Share Posted September 4, 2006 Yeah which is fine until the water hits high temps and drags the oil temp up, which is crap.If you ditch the the heat exchanger and use a thermostatic take off you will find the oil warms up quicker anyway....at least I did.Also the heat exchangers are known for failing, remove it and you remove a point of failure. Link to post Share on other sites
Petesvw 0 Posted September 4, 2006 Report Share Posted September 4, 2006 Any one else got any more views on this? Link to post Share on other sites
mk3anni 0 Posted September 4, 2006 Report Share Posted September 4, 2006 Mine will be for sale soon if anyone wants it <------shameless plug Link to post Share on other sites
Petesvw 0 Posted September 4, 2006 Report Share Posted September 4, 2006 LMAO, why and how much steve? Link to post Share on other sites
mk3anni 0 Posted September 5, 2006 Report Share Posted September 5, 2006 Selling up.Putting the car back to standard and buying a house and something a bit less expensive to run!!! Link to post Share on other sites
VR6Rich 3 Posted September 14, 2006 Report Share Posted September 14, 2006 Cough cough, Steve, we need to have words ;-) Link to post Share on other sites
