help oil cooler fitting problems
Guest spiked69
Guest spiked69
help have just brought a mocal 13 row oil cooler and kit but dont now how to install it as no no instructions were present.Have a corrado vr6 and i assumed that the fitting kit connects to the oil filter some how but cant see how as it has a large plastic cover over the filter.any help would be fantastic
Yeah which is fine until the water hits high temps and drags the oil temp up, which is crap.
If you ditch the the heat exchanger and use a thermostatic take off you will find the oil warms up quicker anyway....at least I did.
Also the heat exchangers are known for failing, remove it and you remove a point of failure.
