jpc 0 Posted August 20, 2006 Report Share Posted August 20, 2006 My VR6 has been missing is the lower rev range when the engine was warm since I've had her, now recently it seems to have been getting worse and missing whilst cold as well.This morning is was raining (very finely spitting) and when I started her she gave off a very unhappy rumble, I slightly blipped the throttle and she missed like hell and lost power.Switched off and checked the oil, she needed some and was just on the min mark, filled her up, started her and off I went...on the way back home another big miss and a rumble from under the bonnet/car, parked her up outside the flat lifted the bonnet and sure enought.... tick tick tick tick, looking closer I can see a spark from the coil pack just above where a lead goes into it (1st one in the row of 6)Looking closer there seems to be a crack.Now I've read aboutthe epoxy solution, should I remove the coil pack and give it a coat?Is it the outside of the pack that I should be coating (where the crack is)? Whats the best epoxy to use?CheersJp Link to post Share on other sites
purple highline monster 0 Posted August 20, 2006 Report Share Posted August 20, 2006 sealing the crack is supposed to be possible, at the end of the day if your gonna removed the pack you may aswell replace it imo, get a good 2nd hand one or new if you can afford it, it saves doing the job 2 or 3 times in the future! Link to post Share on other sites
dellert 0 Posted August 20, 2006 Report Share Posted August 20, 2006 I must agree, once the plastic is perished and cracked once it will do it over and over again, best to chuck it and replace it. GSF ones are fine and half the cost, think it was BERU. Link to post Share on other sites
VR6Pete 1,455 Posted August 20, 2006 Report Share Posted August 20, 2006 I've just replaced my coilpack on my VR6. got it from GSF and yes, it's a BURU. Changed my plugs at the same time while my manifold was off. It's running 100% better than before! Link to post Share on other sites
guppers 0 Posted August 20, 2006 Report Share Posted August 20, 2006 new coil pack. if somethings broke replace it. Link to post Share on other sites
jpc 0 Posted August 20, 2006 Author Report Share Posted August 20, 2006 Thanks for the replies guys, think I will change it.I have a 97P OB2 VR6, is this the right one?? (pasted below)92526 IGNITION COIL/TRANSFORMER G3 VR6 AAA Eng. (Ch.1HP W1480001>) -Distributor 115.00 Add Link to post Share on other sites
VR6Pete 1,455 Posted August 20, 2006 Report Share Posted August 20, 2006 That looks to be a distributer present on the early VR's with yours bein an OBD2 its different.I've not got the part # to hand, but I just phoned them up and gave them my chassis number and bobs your uncle, new coilpack Will you be replacing the spark plugs at the same time? If so, you will need the HT lead removal tool that looks like: Normally located on your bonnet prop. dont use anything else unless you want to risk damaging your leads.Pete Link to post Share on other sites
dellert 0 Posted August 20, 2006 Report Share Posted August 20, 2006 I can vouch for that, in my ignorance before finding VR6OC I just went for it and pulled at the cable! New set of leads, I didnt even learn after the first one! Makes it worse my tool was rubbing against my arm on the prop as I done it!!! Link to post Share on other sites
IbiVR 0 Posted August 20, 2006 Report Share Posted August 20, 2006 my tool was rubbing against my arm :S *sigh, I'm so immature...Tom. Link to post Share on other sites
jpc 0 Posted August 21, 2006 Author Report Share Posted August 21, 2006 92527 IGNITION COIL/TRANSFORMER G3 VR6 AAA Eng. +Distributor 82.50 Add I think that one is the one if you have a dizzy, it;s prob worth changing the plugs they are due in the service in 3K anyways Link to post Share on other sites
VR6Pete 1,455 Posted August 21, 2006 Report Share Posted August 21, 2006 ahh yes, i think your right! I failed to miss the + and the - Distributer bit Pete Link to post Share on other sites
jpc 0 Posted August 21, 2006 Author Report Share Posted August 21, 2006 Best price i've found is herefor the Beru one Link to post Share on other sites
