Geastb 0 Posted June 9, 2004 Report Share Posted June 9, 2004 I'm thinking of getting a shrick soon (possible group buy???) but i've noticed my car is burning quite a bit of oil (now i've got upswept pipes i can see the blue smoke behind me when pulling away sometimes) Should I get a new engine/recondition my old engine and leave the shrick for now or should i just get the shrick and hope the engine lasts a bit longer before getting it sorted at a later date? :? I don't think i can afford to do both at the same time! But I don't really want to miss out on the group buy again(if it happens of course) Also what are the sypmtoms of worn bores? Link to post Share on other sites
mightyvr6 0 Posted June 9, 2004 Report Share Posted June 9, 2004 Pull spark plugs 1 and 6 and check for oily deposits. If they are oily black instead of light grey you could well have bore ovalisation. Link to post Share on other sites
Geastb 0 Posted June 9, 2004 Author Report Share Posted June 9, 2004 Is this easy/expensive to fix? Or a new engine? Link to post Share on other sites
mightyvr6 0 Posted June 9, 2004 Report Share Posted June 9, 2004 I'd get all the tests done first to confirm, could be a cylinder head problem. Bore wear is more common on the 2.9 unit but 2.8 does suffer too. If the block is worn you've got the option of an overbore to 2.9/3.0 which is big money or picking up a second hand block/engine. The later is probably the cheaper option or you could leave it if compression is still reasonable. Link to post Share on other sites
Geastb 0 Posted June 10, 2004 Author Report Share Posted June 10, 2004 I did think my head gasket was leaking (slight oil film in water etc..) could this be the problem?I'll get the tests done asap! Link to post Share on other sites
FishWick 21 Posted June 10, 2004 Report Share Posted June 10, 2004 Find a garage that can do a leakdown test as that will tell you if the gas leak is at the head or block end, or both if you're really unlucky. Link to post Share on other sites
madmonkee 0 Posted June 12, 2004 Report Share Posted June 12, 2004 new engine vege or wege is £1400 2.9 vr6 Link to post Share on other sites
