garonvr6cabby
  • Content count
    22
About garonvr6cabby
    Leicester
  • Interests
    Vws, Jap cars, santa pod drag days
  1. garonvr6cabby
  2. Obd2 vr6 engine, box, loom, ecu
    I have obd2 sitting in my garage doing nothing have the engine gearbox drive shafts ecu wiring only problem is I'm located in Leicester Sent from my GT-N7100 using The VR6 Owners Club mobile app
  3. BBS RX11's 5x100
    What sort of wheels you wanting to swap with
  4. Al's mk3 vr6 turbo build
    Can't wait to see this in person looks awesome
  5. Pile of pvw magazines
    Where about are you so I no
  6. Pile of pvw magazines
    Still got these
  7. Parts needed turbo build
    Thanks pal 450bhp will do me nicely if poss or ill take 350 if it more likely
  8. Hello from essex UK :) new member , first vr6 build
    Well if you need any head work or owt give me a shout [emoji5] might always bump into each other anyway if you attend any vw shows
  9. Hello from essex UK :) new member , first vr6 build
    I'm in Leicester. Work at welham motor Co doing engine recons
  10. Hello from essex UK :) new member , first vr6 build
    That is strange at my place we tell the customer exactly what we do and they take the scrap bits if wanted
  11. Hello from essex UK :) new member , first vr6 build
    Have they done a good vacuum test on it as it could leaking air
  12. Hello from essex UK :) new member , first vr6 build
    There probably rebuilding it to sell
  13. Hello from essex UK :) new member , first vr6 build
    Ouch. Well at least it done and running again I can't believe they refused to work on old head it would have been fine to use. I'm rebuilding a head for someone at min they had head gasket go
  14. Parts needed turbo build
    Yo peeps. I'm buying a vr6 engine to rebuild and turbo it ill be using standard internals with head spacer and new con rods. But I could really do with a part list so I know what parts I need for the turbo part of the build any help would be appreciated
  15. Hello from essex UK :) new member , first vr6 build
    Did you get the head sorted on this in the end
