B-Man
Days Won
2
Everything posted by B-Man
£25 collection preferred due to size. Based in Sutton,Surrey. Thanks! Sent from my iPhone using Tapatalk
Lol...havnt had the time yet! All work and no play!
Whoohooo! Problem solved! Thanks to J4Y VR for the very helpfull info! So that means its proper test drive time! Will get a vid and some pics up soon! Sent from my iPhone using Tapatalk
Using the BMW wire so def good on that. Just spoke to J4Y VR and I think he just shook my memory and there might be some wires that I havent put back...i will check this afternoon and keep u posted! Sent from my iPhone using Tapatalk
No... Sent from my iPhone using Tapatalk
O.k ill give that a go,thanks! Could u give me like a basic route dor all the wires etc...i.e. Where from and to the wires should go when the battery is relocated just so I can double check them? Sent from my iPhone using Tapatalk
Not intermittent,when ignition is on,the guages move i.e fuel guage etc but as soon as I start her then I loose them all...all lights etc work but no "needles" if that makes sense. Sent from my iPhone using Tapatalk
Loosing all guages when car is running. Dash works perfect but just the guages that dont work when car is running. Battery was relocated to the boot so im guessing its that but ive moved the earthing points thinking it might be that but still no luck! This is what the dude used... Block up front... In boot...negative was mounted somewhere else but I moved it there to see if it will make a difference so the neg wire is a bit long as u can see Sent from my iPhone using Tapatalk
Thats cool mate,ya just around the corner. Well I just went down this route as it saved me a good few ££ but having it profesionally installed you have some piece of mind its installed o.k. This was my first attempt so hope it holds! Sent from my iPhone using Tapatalk
Hi mate. Yes she is running but still have the dash problem so havent taken her for a decent ride yet,very frustrating! Trying to aolve that issue first but not getting very far! Sent from my iPhone using Tapatalk
That Junction box o.k? Sent from my iPhone using Tapatalk
So I just checked where the earth frol battery was located and he ran it to the body just infront of the back seats...so I took it off and mounted it to where it is now in the pic to see if that will make a difference but it doesnt... Will the lenght of the negative cable affect it as it is a bit long... At the back... Block at front... Sent from my iPhone using Tapatalk
Ive got something like this up front... Sent from my iPhone using Tapatalk
Gordon...any reccomendations fo a block apart from the BMW one? Have u maybe got a pic? Also where did u mount the earth from the battery in the boot? Sent from my iPhone using Tapatalk
Well i had it done...but not sure on the junction box if honest,dont look that great. Ill take a pic later of it. I bought BMW cable anyway and that is being used. Only the pos though. Sent from my iPhone using Tapatalk
Hi. So after installing a Turbo and having the battery relocated to the boot I am loosing my dash guages when the car is running which I think is a earth issue from relocation. As im now fed up im going to put everything back up front but need to use a battery as small as possible to fit upfront with all the Turbo pipes etc but powerfull enough. Racing battery as sold by DeamonTweaks... Sent from my iPhone using Tapatalk
So Ive noticed that the fuel guage sometimes comes on and sometimes dies when running....so im almost sure its an earth issue...? Here is how the guy did the battery relocation... Original negative that ran to battery mounted to body up front. Then all power cables connected to a block up front with positive battery cable running from there to the battery in boot. Earth from battery in boot mounted to seat belt bolt... Does that sound right? Sent from my iPhone using Tapatalk
Lol...soon chaps! I have one of her idling at the moment,but will go pro the test ride! Sent from my iPhone using Tapatalk
Hi mate, Ya its done. Havent driven her yet as rad sprung a leak and fuel rail bleeder screw so putting on new ones tomorrow then its test drive time! Starts and sounds lovely though! Sent from my iPhone using Tapatalk
Hi all, Upon starting the rev counter,fuel guage,heat guage and LED display dies. The car idles fine etc. orior to starting when you turn the ignition on all lights and guages work as they should,even when the car is running everything works apart from the above mentioned guagea?? Just recently installed a Turbo and part of that was moving the battery to the boot. All earths were checked and all are fine. Anyone have any idea what it could be or is it just my clocks thats at fault? Just find it a bit of a co-incidence after the install? Thanks! Sent from my iPhone using Tapatalk
Thanks! Yes it is but just hope i get to drive her before then! Sent from my iPhone using Tapatalk
Cheers mate,just niggly bits are annoying me now,front has to come off tomorrow again to fit another rad! Then hopefully I can actually take her for a test ride. Sent from my iPhone using Tapatalk
Ya thats the one! Rad now seems to have sprung a leak! Argh! Sent from my iPhone using Tapatalk
So she started! Had a tiny fuel leak from one injector,think that is now sorted. Then a leak from the screw in the fuel rail...only just temp fixed that...any idea as to where to get one of those screws? Think the washer has gone. As she stands now.... Ill get a vid up if her running soon...cant seem to do it via tapatalk... Sent from my iPhone using Tapatalk
