Chingy
Everything posted by Chingy
  1. Chingy
    Door panels..
    lol u here too! hahaha. mal naai. i will when the head is back on, the gasket was in its poes he said.
  2. Chingy
    Door panels..
    Thanx a million ok
  3. Chingy
    Door panels..
    What is the proper way of removing a door panel from a Jetta \ Golf VR6 without breaking anything?
  4. Since a vr6 has a common gearbox problem (a friend of mine had about 4 boxes in his before selling), what gearbox can we fit on here that gives less problems? Another friend of mine has a 6 speed box in his, im not sure what box it is but i think its a 1.9tdi box? I would like to know this as when or if my box goes, i dont want to replace it with another box that will break soon..
  5. Id like some advise about lowering my car. I love a car to be EXTREMELY low... Is there any way available to lower my car while still having the soft ride of standard height, or is it a general rule, the lower you go, the harder the ride? Id like to fit coilovers inmy Jetta Vr6, because i cant obtain a plus minus 80mm drop like i would like. I have heard some people say coilovers will be softer than cut springs, but proof is in the pudding/./
  6. Thanx for the help guys the uncommon tyre sizes here are quite expensive for such a narrow tyre ( im looking at putting 165 40 15 on my 6.5j standard vr6 rim ). They want R1300 per tye which is about 130pounds. What prices do you guys get on tyes?
  7. that is exactly what i wanted to hear thank u! so u say if u drive hard, it could be dangerous because tyre could maybe pull off?
  8. Here in South Africa we got the Golf VR6 and we got the Jetta VR6(saloon). The Jetta came out with different rims on, one being the bbs rim, and another which was a really ugly set of rims that said VR6 on the centre cap. The golf however came out with another sit of rims which are quite nice, and I dont think i have seen any of your guys cars with these on, correct me if im wrong by thinking that it never came out on UK models? (how do i post pics??)
  9. I see that some of your tire sidewalls are normal shaped, and some have this slant likie the tire is too small for the rim(where ist looks like it stretches and pulls towards the lip of the rim). Hows does this work? is it a certain tire? I think this looks really nice but no cars really have that going on here in South Africa. Please let me know
  10. okay il do so. But its still leaking because of the leak, not because of the oil im guessing? Il buy some of it from vw tomorrow.
  11. the whole lot, meaning mechanism and motor? Condition? But we have a problem.. Look at my location.. south africa?
  12. lol. Oh ok. But as i mentioned in another topic, mine is leaking somewhere, which il check out on wednesday.
  13. shit thats a little expensive for now. Il do it next month and just make a plan to keep the window up so long. But still, im wondering if it really needs replacing or not though.. Also, if it is indeed that plastic stop that you are talking of, i wonder if vw doesnt perhaps sell the part seperate.. Il find out tomorrow
  14. a new rack sounds expensive on this car.. Its going to the mechanic on wednesday then he can tell me. I couldnt really see from what pipe it was leaking. I put in automatic transmission fluid, it should work with all power steering?
  15. filled the car with the fluid since the bottle was empty when i got the car. It works, but it starts dripping,and drops on the ground below the driver side control arm (our cars are right hand drive). Anyone know what the problem is before i send it away?
  16. i got the car with the driver window about 10cm from closing. Today i took door panel off and tested the window, so it went all the way down smoothly, but when i tried making it go back up, it goes a little less than half way up, then automatically goes down by itself. Any clue? I removed the whole unit, and re fitted it making sure nothing is in the way, and still does the same..
  17. one question, it might be stupid, but will the powerstering still work if there is no fluid in it?
  18. i rate it needs that due to fuel consumption
  19. When the car drives il tell u if the head gasket is blown or not. When u say replace it, do u mean the O rings, or the whole crack pipe? How much is the whole pipe?
  20. when i got the car, the guy told me that its the oil cooler. Alot of other people told me the same thing. So i have replaced the oil cooler, but the car cant drive yet because its leaking water from the long plastic pipe above the oil cooler. Firstly, is it only the oil cooler that causes that, or could it have been head gasket too? Keeping in mind that the car does start and sounds healthy, although i have not driven it around as yet. Secondly, that long plastic water pipe above the oil cooler, i was told that it has a O-ring on each side. Mind is leaking water from the left side (the side th
