Mr Grumpy
About Mr Grumpy
    Dorset
  1. Hi, FlySpeck WoW!! THANK YOU for the quick reply, it is very much appreciated, this is doing my head!! What I have tried so far, I have removed and checked the starter motor, including the usual suspect braided solenoid lead. All working OK, replaced it cleaning all earth connections. I have checked as many fuses as I can find and everything appears to work including the alarm (Clifford) I have also tried a new ignition switch. However when I turn the key nothing from the starter or solenoid just silence. If I bridge the starter motor the car starts. I have not checked any relays as I did not
  2. Hi, I have the same problem on a VR6, did the OP or anyone else find or can offer a solution??
  3. Hi Shail Thanks for the prompt reply, I will check behind the dials in the morning.
  4. hi Calico Thanks for the prompt reply. yes the fan is working, Blows very cold air!!
  5. Hi Gents Did you manage to solve this? as i have the same problem, had a new matrix fitted. (I do not know if heater worked before new matrix as the matrix was bypassed when I aquired the car) No coolant leaks, car runs at constant temperature (90) both pipes to/from matrix hot, but no heater?? Any help would be appreciated, fed up with my daughter constantly moaning about being cold!!
  6. Hi, Did you manage to sort this? as I have the same problem!
  7. hi, are you loosing coolant? Also does the screen steam up when you turn the heater on full, when engine at running temperature. if so probably the heater matrix.
  8. I have two, a 20-year-old son who is training to be an accountant! He drives a S----u. and an 18-year-old daughter a complete petrol head, she has just acquired a VR6. Helping her with the VR led to me acquiring one myself and joining this club. Pic. of my daughters VR with the machines she drives for work (weather permitting)
  9. Hi VR6 Nat LC6P, my daughters is also LC6P, however, she is not yet a member! I am still trying to get her to join, I have told her she would not be the only girl! (young lady)
