About sparkyjr
london
Right guys its the motor, tried hitting it to try and free it but nothing and cant find front drivers side one on ebay any one got a trusted shop please?
Thanks for this just followed link unfortunately can't find front right for the mk3, could u pos send the product no. Sorry thanks again for the help
My drivers side window just gave up the other day with no warning.The strange thing is when ideling if i press it i hear a little click and engine dips a bit, up or down. I have read other post but every one says they can hear sounds from the window trying to move but i hear nothing except the single click noise from the switch area. Please can some one help or advice me on any tests to do. Also one final this my alarm has a function were if the car is locked and unlock the windows open 5 inches and does not do it on drivers side ruling out switch in my oppion. Thanks
I take it the one from halfords is water proof?
Was thinking about getting a car cover but have heard some can scratch when it is windy. Any one has any comment would be appriated .
Does any one know were I can buy a alarm bonnet contact, the difficulty I'm having is it has two contacts which is a older system. I want a desect one if possible. Any helped welcome thanks
I am after set of black mk4 style head ights but i can only find lhd from venom and was wondering if there is a way of convering them or if any one can point me in the directin of were to buy them?
Just a qick note re that buzzing when ignition is turned on, i took off the tb sensor and put it back on and buzzing has gone as i thought i had never heard it. May be it was not seated quite right just thought i would mention it so you may want to have a look at yours?
right to put a cap on this thread, you lot was wright gsf leads are crap they was on propperly but did not make good connection causing misfiring ect. dubpower very kindly sent me a single lead and they work great and for only £30 just concerned as they are a bit longer and i think may cause problems with schrick bending them over. Thanks all for help
Cheers mate will keep trying tonight. What is the tb? Never noticed the noise before.
Bump
I have just bought some bbt leads from gsf and when fitting them they dont seem to go on tightly so much so i can pull them off with out tool really easly. I have tried using the removing tool to push the top of the cap but it seems to get stuck and ends up pulling it off. Please help. Also since one of the spark plugs broke when i turn on the ignition there is a faint buzzing stops after a few sec but think it starts again when i start engine .Started after disconecting batterie (could be some thing to do with immobiliser) but your the experts. Thanks
Does that b and m short shift shorten the throws of each gear shift? ( sorry if it's a stupid question) and do they make a big dfference in speeding up gear changes?
Just thought I would put in my input, had my schrick and shimmel cams fitted by gwerks and asked about a remap and was told it was not needed as the ecu will learn and adjust after 30 od miles. I read loads of people saying I would not get full benefit unless I had a remap, at the end of the day gwerks are experts and they know best.
Cool I thought as much, what sort of power gains did u get from them?
