jabe
Everything posted by jabe
I've bought powerflex poly bushes for the subframe. I've got it off the car. There seems to be a large washer on the top of the bush and the bar that connects the two bushes below. I can't remove either of these they seem welded to the metal tube through the bush. How do I remove these? Any tricks ? I assume they must come apart and that I reuse the washer and tube on the new bushes. Any help would be appreciated !!! Cheers Jason
I'm looking for a vr6 sub frame, with all bolts please. I'm in Peterborough so the nearer the better. Cheers
It's all to do with the Abs fault I had it on mine. Replace the abs light and scan for fault codes will most probably be a sensor. Sent from my iPhone using Tapatalk
I don't imagine it can be relocated well the standard one anyway. Do guys not usually switch to single race car style ones and new pedal boxes ? Cheers
I had this on my Vr. Turned out to be battery needing charged. It would do exactly as you describe. Die unless I gave it revs and rev terrible. Could be other things I'm sure. Start with the easiest first ! Hope u get it sorted.
Cheers Pete, I'm in a single garage and space is bloody tight. I wanted to avoid the hassle of engine out. If it needs to then ill need to bite the bullet ! Any ideas are mk3 sub frames all the same or must it be a Vr one? Cheers
I hate my car. Why does it fight me so much on everything ? Is it possible to drop the subframe without removing the engine and box ? I was thinking support engine with jacks and hoist. Tie up steering rack and bobs your uncle. ! Any thoughts ? Cheers
Cheers for the help. It's worse than I thought. I snapped the front mount bolt. I knew I'd done it but thought it had snapped just inside the threaded hole. Nope I've got just enough thread to stop the arm from pulling out. Any more ideas ? Cheers Jason
Is this not an air con drain or something like that?
Thanks Pete, Really appreciate you doing that for me. Cheers
Not sure if this is the right place but here goes ! I know you are having issues sorting it out with the new site. Any ideas when I'll be back on ? Could do with access to the guides. Cheers
Front arm mate, any ideas if there's a washer or plate which locks the bush in ? I've done the arm and bushes on my last one and it came out without any hassle ! Cheers
I've got everything stripped down and all bolts out but the arm don't want to budge out of its mounting points. Seems to be held in place somehow. any ideas to help me out ? Cheers guys
Cheers guys. Thats my next mission
Do I need to remove the sump to get the front bolt out ? I've been told I can jack up the engine . Any ideas ? Cheers Jason
I have a servo for sale and have been asked if its a 22mm . Can you help me out - What size is a vr6 servo ? Its from a 97 model if that makes any difference. Cheers Jase
SHOULD I PART EX MY BMW 318 CI FOR A MULBERRY VR6 HIGHLINE????? HELP!
jabe replied to zoobz's topic in General Chat
That looks like my brothers old vr. Mechanically well looked after. It's your decision mate, you'll only get biased views on here ! It's usually the test drive that sells a car. What did you think ? Jase -
My bro's car had this problem - only got switched live to radio on first click no lights. Any other position it was dead. We just used the perm feed. Just need to remember to switch it off ! Or replace the switch? Cheers Jase
Looks much better on those wheels stu. Whats next ? Jase
I swapped out my engine for a lower mileage one a while ago. I decided to have a look at the chains tensioners etc. The upper guide has lost a big chunk (exactly the same place as the picture in the replacement guide in the knowledge vault!) This bit has then fallen down and got caught in the lower chain and guide.Its actually snapped the lower guide near the mount. Glad I changed engines now. I did know about the upper guide thats why I swapped. Its amazing the damage a bit of plastic can do !
I thought this and nearly drilled it out. Its actually a 5 or 6mm allen key hex headed bolt.
Mounting vr engine on a stand - any ideas ?
jabe replied to jabe's topic in Engine Maintenance and Problems
Never thought of that. Cheers for your help -
I'm wanting to do the chain guides and have an engine stand in the garage. The problem i've got is how do i mount the engine on the stand- usually you'd use the gearbox mount holes. But i need access to this end of the engine. Any ideas? Cheers Jase
Thanks, car seems to be costing me a fortune at the mo and i hardly drive it ! But I love it so - it's only money ! Cheers craggsy Jason
Just plugged my car in and came up with a few codes - faults i'd just fixed and one I don't understand. Fault code 01247 evap canister purge solenoid - N115 Any ideas what this means ? Is it the solenoid near the air box ? Will this make my emmissions(spelling?) high for mot ? Any help appreciated. Cheers Jason
