Everything posted by toofunkyhouse
word up all, just after some feedback, i have some 17" wheels on the car at the mo which are ok but i also have the bbs wheels which came with the car. I was maybe thinking of refurbing them in anthracite. What do you guys think would look better, keep the 17"s or go back to 15"'s? cheers, rob
cheers for the info, got in using an old wire coat hanger! lol
locked out the vr, de-locked and the boot lock doesnt match the car, can you get to the bonnet catch when the car is sat?? grrrrrrrrrrr
thankyou, yeah the 8 ball is just a bit of fun, my old one was really worn and picked this up for 8 quid.
a few pics of the old gal at spring fest, have now painted the bumper vents and also picked up a cheap wheel. think i will have to get a momo or sparco as this one feels too crappy!
ha dont worry buddy, i have one in mine, my gear noob was fooked and i kind of like the old 8 ball look! goes with my fury dice! lol
had a good day, some sweet ass rides! shame the weather turned at the end
well i guess the garage can sort that out for me...... i hope! couldnt just leave a hole with the weather as it is
was working on mine the other day and as mine is low i have to use the vw jack then a trolly jack but it decided to fall off the vw jack and put a nice big hole in one of my sills! have wax oiled the hole but i need to get it welded up! not a happy bunny, also bent the skirt a bit
car has slight hesitation when under load
toofunkyhouse replied to toofunkyhouse's topic in Engine Maintenance and Problems
ah ok, only left it a few mins in position 1. will give that a try when its not raining, thankyou rob -
i did reset it by taking the bat off for an hour as at first it was at idle at 1700rpm but its ok for that now, tried using vag com to do it but it wouldnt work for some reason -
how much can a vr6 engine take?
toofunkyhouse replied to H13VYY's topic in Engine Maintenance and Problems
when i got mine it had about 125k on her, ran sweet as a nut, have done 5k in her and i drive quite hard, once car is up to temp i hit 5k on most gear changes (just love the sound it makes over 4k) seem to be fine still, has a slight stutter in the engine but this seems to have happend since i took the throttle body off and cleaned and ported it. they seem to be very good engines, mine uses no oil or water either -
what and where is the charcoal filter
do you know what it does? -
nice one, thankyou -
cheers for that, but read through a few threads and found something about resetting the throttel body. i took the neg lead off the battery and reconnected it and then tunrned the key to the first postion then started her, seem to be fine now, cant say that its got anymore power but seems to be getting better mpg round town which will do me. yeah will change sig when i get time
hi all, well today i took off my throttle body all pipe and maf to clean them out (didnt reall clean the maf as it looked ok. i also used my dremel to smooth out the throttle body a bit, put it all back on but now the car idles at about 1700 rpm it will drop in the end to about 1100 but as soon as you bilp the throttle it goes back to about 1900 then kind of hunts about, any ideas?? why do i mess with cars!! grrr
hi all, used a mates vag com on my vr and these codes came back, now the car is running fine so would just like to know what these mean and what i should be looking at fixing under the bonnet. many thanks, rob Address 01: Engine Controller: 021 906 256 Component: MOTRONIC M3.8.1 HS V02 Coding: 00000 Shop #: WSC 01317 4 Faults Found: 00668 - Supply Voltage Terminal 30 07-10 - Signal too Low - Intermittent 00533 - Idle Speed Regulation 14-00 - Adaptation Limit (Add) Exceeded 00561 - Mixture Adaptation 15-00 - Adaptation Limit (Add) Not Reached 01
right bit of an up-date, had a new front wing fitted also changed the front splitter as it had got messed up a bit and also didnt really fit. also fitted a new 8 ball gear nob and a metal trim round the clocks. [img:width=600]http://img.photobucket.com/albums/v732/Toofunkyhouse/DSC00022.jpg[/img:width=600] [img:width=600]http://img.photobucket.com/albums/v732/Toofunkyhouse/DSC00023-1.jpg[/img:width=600] [img:width=600]http://img.photobucket.com/albums/v732/Toofunkyhouse/DSC00040.jpg[/img:width=600] [img:width=600]http://img.photobucket.com/albums/v732/Toofunkyhouse/DSC00041-1.jpg[/img:w
yeah i thought it might wreck the inner bit of the tyres but seems ok, done 5k like this and the tyres seem normal!
well i also put the camber to max neg so the wheels tuck in more
hi at first it did so i took it up by about 5 mm and seems fine at the front now, it does rub at the back on big bumps but only on the passenger side. i have taken out the plastic at the front, arches are standard but i would like to get them rolled at the back so i can drop it a tad more
right bit of an update - have fitted new fogs/indicators, fitted new number plates, sprayed my new delocked handles, fitted a vibe sub and also fitted some green led's to the clocks +sprayed the needles orange getting a new drivers wing soon, still need to sort a chili red tailgate!! anyone?? oh and fitted some new bumper vents, not sure if i should colour code them or not?? Moderator edit by: SankysVR6
http://www.no-rice.com/forum/index.php?p=vt&tid=25812
