sooty
Everything posted by sooty
  1. thanks for your help guys and gals sorted it the water pump was fcuked 8-)
  2. hi vdubgirl if you need a hand sorting out bins skips etc anything to do with the disposal of waste not local to northhampton but deal with some waste management companys in and around that area give us a shout !!!
  3. hi mate i had a bad misfire on mine and also changed the plugs leads coilpack ect..... and it turned out to be the hall sensor (camshaft sensor) they are expensive but a quick clean might do the trick it is located behind your coilpack
  4. hi all just wondered if anyone can shed some light on a water leak that has developed i have a 94 obd1 vr6 104k it has always used a drop of water but over the last week i have been topping it up every day thought it could be the cap or bottle so changed both since doing that have seen water appearing behind the airbox around the pulley next to the alternator pulley also the main water hose is pressured all the time when running is that normal? it didnt do that before i put the bottle and cap on only when you revved it up please help thanks *-)
  5. L with 103k on it sweet as a nut
