jezmoz
Everything posted by jezmoz
  1. Good weekend, Feeling it this morning though, not caught up from the 5.30am bender with Nigel and Chris Top weather as well.
  2. you will need to swap the engine manifold, throttle body ,ecu, loom, you'll also need the immobiliser loom etc A lot of hassle for 10bhp! From experience its not worth it although mine was a swap from obd1 to obd2 but my obd1 was dead!!
  3. I'll hopefully see you all there If there's any room on the stand i'll dump the R on it if that's okay?
  4. Just want to say cheers to Nigel for the hospitality, top set up mate and the Orbital just made the night for me , also Jake and his rare treat.
  5. jezmoz
    Rocco R
    no v6 lump the end of an era
  6. grasping at straws lol http://www.edition38.com/forums/index.php?showtopic=229304
  7. cheers lads, a worthy predecessor. Still miss my vr though put a lot of blood, sweat and tears into that bloody thing!
  8. My beloved vr has gone to scrap heaven so i decided to ditch the mk3 and get one of these beauties
  9. i didn't have one for my last and final mot, sailed through on emissions
  10. As said he can't of been trying, My mate had an m3 e36 and it was "dangerous". They make Vrs look very average!! I couldn't wait to get out of it...death machines.
  11. Prices for mk3 vr6 will only drop further as the mileage and age rises. Mk4 R32s have lost 5k in a year?? Only the cleanest, lower mileage Vr6s can fetch better money and they are like rocking horse sh1t!!
  12. see if relay is sat correctly Relays Relay No. Description 1 Air conditioning 2 Rear Wiper 3 Digifant control unit (except 16-valve) 4 Load reduction relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Open 8 Intermittent wipers 9 Seat belt warning system control unit (possibly headlight warning too?) 10 Fog lights 11 Horn 12 Fuel pump (except diesel)Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay 14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve
  13. I concur only worth buying if you're changing the cams as well
  14. just thought i'd give the fully comp boys the heads up, got a right crack down my windscreen courtesy of a lorry and what appeared to be half a brick. Anyway red star equity put me through to Autoglass, they were fine about it, but i said I wanted a genuine VW windcreen and not some generic tosh. That'll be an extra 47.41p sir and you'll need to get a number and name from red star to get authorisation. Now have a genuine windcreen on order £70 excess. Not bad eh. No claims unaffected. Cheers mr lorry driver because my old windscreen wasn't a genuine one :):)
  15. I wouldn't bother unless you change cams and or decat and have a decent exhaust as it makes no difference at all without cams. makes a nice noise though
  16. eh? you got the right bolt? its just a screw in bolt use some pliers to grip it.
  17. yes if you have a big wallet, you can get a skyline twin turbo with silly bhp out of the box for around the same price as a vr!!!
  18. yes it was mate, 15.3 is a good time for an obd1 nice one
  19. must have been you i was chatting to then mate you were in the white vr with no headlight?
