Russ_vr6 12 Posted July 3, 2006 Report Share Posted July 3, 2006 well pressure tested my cooling system this morning,losing pressure but no leaks and driving home temp needle shoots up to 3/4 (usually sits at 75-80) then returns to normal,so get home,check the oil,and low n behold there bubbles in the oil :-( let it cool a bit,tried undoing the coolant cap and pressure is unbelievable,so have 2 leave it longerso pointing 2wards head gasket i suppose Link to post Share on other sites
stuey 0 Posted July 3, 2006 Report Share Posted July 3, 2006 This must be the season for it, i think mine went on saturday night. Temp shot up, no visible leaks and tons of air in the system :-( Link to post Share on other sites
riggs 0 Posted July 3, 2006 Report Share Posted July 3, 2006 Looks like mine went on sunday night also :-( ( Group Buy on gasket and headbolts?) (m) Link to post Share on other sites
Russ_vr6 12 Posted July 4, 2006 Author Report Share Posted July 4, 2006 lol im lucky,as i work for vw,so im determined to fix it for under £250 Link to post Share on other sites
stuey 0 Posted July 4, 2006 Report Share Posted July 4, 2006 How about a group buy for lucky rabbits feet?? Link to post Share on other sites
riggs 0 Posted July 4, 2006 Report Share Posted July 4, 2006 lol im lucky' date='as i work for vw,so im determined to fix it for under £250[/quote'] Want to do another one?? Link to post Share on other sites
Russ_vr6 12 Posted July 4, 2006 Author Report Share Posted July 4, 2006 that would do loljus priced the bits up and everythin has come to 182 quid thats including the inlet manifold gaskets too,might not need them,which will take price down to 165 Link to post Share on other sites
riggs 0 Posted July 4, 2006 Report Share Posted July 4, 2006 You lucky man ! im expecting anywhere above £500 min Link to post Share on other sites
Russ_vr6 12 Posted July 4, 2006 Author Report Share Posted July 4, 2006 i take it that is labour and parts matey? Link to post Share on other sites
riggs 0 Posted July 4, 2006 Report Share Posted July 4, 2006 Yup : ( Link to post Share on other sites
Russ_vr6 12 Posted July 4, 2006 Author Report Share Posted July 4, 2006 well look at it this way mate we have jus done one on a vr corrado and the totsl bill came to 980!!!!!!!!thats hould make u feel a little better lolwhats the miles on urs mate? Link to post Share on other sites
riggs 0 Posted July 4, 2006 Report Share Posted July 4, 2006 She's only done 65,000 wtf? Link to post Share on other sites
Russ_vr6 12 Posted July 4, 2006 Author Report Share Posted July 4, 2006 pretty good miles mate but they go with age too,jus one of those things im afraidi thinkin of chuckin on a bvh if i can raise 500 quid by the end of the week lol Link to post Share on other sites
Russ_vr6 12 Posted July 5, 2006 Author Report Share Posted July 5, 2006 update:well brought her into work today and took her out last nite also,and she is running perfect and no high temp at all.... Link to post Share on other sites
FishWick 21 Posted July 5, 2006 Report Share Posted July 5, 2006 It's worth noting VW have now uprgraded the VR gaskets to metal ones. I believe they also knock the compression ratio up to about 10.2:1 as they're only about a mill thick.I think Stealth still stock the original Victor Reinz gaskets.In this summer heat, keep the engines as cool as possible. Leave the heater on in the car on speed 1 (open the windows!), stick some redline water wetter in, and wire up speed 3 to a switch on the dash. Prevention is better than the cure :-) Link to post Share on other sites
Russ_vr6 12 Posted July 5, 2006 Author Report Share Posted July 5, 2006 more update:jus noticed the coolant temp sensor housing is leakin,so fingers crossed Link to post Share on other sites
Russ_vr6 12 Posted July 6, 2006 Author Report Share Posted July 6, 2006 everybody check this on urs as i didnt notice this leak Link to post Share on other sites
