well pressure tested my cooling system this morning,losing pressure but no leaks and driving home temp needle shoots up to 3/4 (usually sits at 75-80) then returns to normal,so get home,check the oil,and low n behold there bubbles in the oil :-(
let it cool a bit,tried undoing the coolant cap and pressure is unbelievable,so have 2 leave it longer
so pointing 2wards head gasket i suppose
It's worth noting VW have now uprgraded the VR gaskets to metal ones. I believe they also knock the compression ratio up to about 10.2:1 as they're only about a mill thick.
I think Stealth still stock the original Victor Reinz gaskets.
In this summer heat, keep the engines as cool as possible. Leave the heater on in the car on speed 1 (open the windows!), stick some redline water wetter in, and wire up speed 3 to a switch on the dash. Prevention is better than the cure :-)
