Guest stevescaife Posted April 25, 2006 Report Share Posted April 25, 2006 Hi AllI have an L reg Golf VR6 with 135k on the clock and everything on the car works as it should except my seats. Not that bothered but I would like them working when i come to sell the car.Both of my front heated seats don't work. How do I go about checking whats wrong with them? Thanks all Link to post Share on other sites
vr6madmike 0 Posted April 25, 2006 Report Share Posted April 25, 2006 Chect the fuses, then the wiring loom that goes into the seat, if the seat has been moved back and forth a lot its common 4 the wire to come loose, if not then its the element. Link to post Share on other sites
Guest stevescaife Posted April 26, 2006 Report Share Posted April 26, 2006 Cheers will have a look when it stops raining!! Link to post Share on other sites
stuey 0 Posted April 26, 2006 Report Share Posted April 26, 2006 I have the same problem, there are relays under the seats which you can check. Find a quiet place, and turn each seat on one at a time. If you put your ear near the front of the seats low down you should hear a click. If you do the relays should be ok, and the wiring to them. Mine click ok but there is no heat from any part of the seats, it is probably the elements If anyone knows better it would be good to hear. Link to post Share on other sites
Guest stevescaife Posted April 28, 2006 Report Share Posted April 28, 2006 Well!! One seat doesn't have a relay and the other seat the relay doesn't click!! Where can I get these relays fron cheap?? :? Link to post Share on other sites
stuey 0 Posted May 1, 2006 Report Share Posted May 1, 2006 I don't know about cheap, VW might not be too bad. You could try swapping your relay to the other side to test it before buying new ones, just in case it is the wiring or the rotary switches. Since you need one relay anyway, get two and try one of them to see if it fixes the fault. If not hopefully you can take one back. Link to post Share on other sites
markrob 0 Posted November 8, 2006 Report Share Posted November 8, 2006 iv got the same problem but both my relays are clicking on but still no heat, what can be done to the elements if its them?mark Link to post Share on other sites
binliner 0 Posted November 9, 2006 Report Share Posted November 9, 2006 relays are £35... Ive just bought one Link to post Share on other sites
Jk* 0 Posted November 20, 2006 Report Share Posted November 20, 2006 relays are £35... Ive just bought oneOuch for two! Link to post Share on other sites
Chrisdut 0 Posted November 20, 2006 Report Share Posted November 20, 2006 no just for one, if the relays are clicking and there is no heat still then the elements are dead, the only way to fix is to replace with new ones, they aint cheap either, had to price up for a bloke the other week, plus the seats need stripping right down to remove and fit new element Link to post Share on other sites
