Geastb 0 Posted May 25, 2004 Report Share Posted May 25, 2004 I've just bought a dual exit backbox with upswept tailpipes(boxster?) just wondered how i go about fitting? It came with no instructions!CheersGaz Link to post Share on other sites
kilokilla 0 Posted May 25, 2004 Report Share Posted May 25, 2004 is it a motex 1 mate if so they are real tight fit i found it easier to just go to exhaust place to get it fitted and took mine off within a week was not impressed. Link to post Share on other sites
kilokilla 0 Posted May 25, 2004 Report Share Posted May 25, 2004 what you have to do is unbolt old backbox and remove depending on how long its been on this can be a mission itself anyways after that you fit your new backbox thenline up where you want the second exit you then need to work out where to put bracket to fit 2nd exit .once youve done all ov this all thats left to do is cut a chunk ov your bumper away where the second exit sits.hope this helps but still say its so much easier to chuck an exhaust fitter £20 and then watch them struggle with it.oh and i do do most ov my own repairs generally cos i dont trust garages. Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 is it a motex 1 mate if so they are real tight fit i found it easier to just go to exhaust place to get it fitted and took mine off within a week was not impressed.Not sure of make (got off ebay!) - why weren't you impressed? Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 well the bracket that was supplied for 2nd exit wasnt strong eneough to keep 2nd exit in position properly and also where it was such a tight fit it just kept rumbling up on floor possibly where my car has had rear damage before but i believe its because main rear silencer is too big for where it needs go if you send me a picture i will let you know if it is same system. Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 I've bolts bracket to fual tank holder bolt - not took old silencer off yet so no idea how its going to go - luckily my G/f bro works at a tyre place so should be able to get any problems sorted!I'll let you know how it goes!Sorry got no dig cam at the moment! Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 see if you can still check this ebay item its the 1 i had and sold see if it same 1 item no 7901260464 Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 Thats the one i got! - I was outbid then the bloke didn't want it so sold it to me for £100 - i'll get the bracket sorted out then!Its a small world! Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 lol isnt it, yes get the spare bracket replaced with summit stronger also i found it helped to spacer rear box mounts with washers so it not so tight to floor but as i said before it could just be where my car has had rear end damage. Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 I'll give it a go - cheers for the info matey. Will hopfully have it all on in the next week or so - will let you know how it goes! Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 cool, it does give a pukka sound mate. Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 Out of interrest which part of the bracket wasn't strong enough? The part that joins the exhaust or the actual bracket that bolts to the body? Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 the spare bracket bar that bolts to body work allthough i did tell the bloke i sold it too so he may have replaced it already as it still got the rubber wedged onnit holding the spare bracket to the 2nd exit Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 Yes still has rubber bit on! I mite try drilling and putting a bolt through it to add extra strength - or is it the pipe piece that isn't strong enough? Iykwim! Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 no its the flat piece that goes along up and along a bit more with hole in it to bolt to floor ov car it just bends. Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 So if i bolt it along from where it already bolts to the floor it should be ok then? Or am i completely wrong?Thanks for all the help btw! Your a star! Link to post Share on other sites
kilokilla 0 Posted May 26, 2004 Report Share Posted May 26, 2004 i get wot your saying but i dont think thatyou will be able to do that cos ov where and how it bolts up if you got mate in tyre and exhaust place he should be able to fabricate something a lot better and stronger to do the job mate i found the best place to bolt it to was on the driver side rear chassis type bar would reccommend you get em to weld a new bracket on to the chassis there cos that bar that was supplied really is useless mate and if you use that i guarantee you will end up removing it and finding something to substitute it so best just getting whole new bar made. Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 Ok i'll get them to look at it! Thanks mate Link to post Share on other sites
Geastb 0 Posted May 26, 2004 Author Report Share Posted May 26, 2004 Btw - your sig "TOKE EM AND SMOKE EM!" Doesn't it mean the same thing? Or have i got wrong end of stick? Link to post Share on other sites
Geastb 0 Posted June 8, 2004 Author Report Share Posted June 8, 2004 Well an update! Got it exhaust fitted today (bell's in swindon) cost me £150 for a s/s straight thru pipe and all to be fitted (very well i might add) Can't believe the difference - sounds lush!!!!! !amazed !amazed Link to post Share on other sites
kilokilla 0 Posted June 8, 2004 Report Share Posted June 8, 2004 Btw - your sig "TOKE EM AND SMOKE EM!" Doesn't it mean the same thing? Or have i got wrong end of stick?lol i like to toke me smoke but when im racing other cars i like to smoke em ie thrash em its actually 2 different things i enjoy doing if you catch me drift.although it could also mean the same thing .i thought it was good sig cos it could be taken either way .he he he Link to post Share on other sites
Geastb 0 Posted June 8, 2004 Author Report Share Posted June 8, 2004 I get you now!!! Nice one! Cheers for selling the exhaust btw - its like a different car now! only downside is i'm using a hell of a lot more fuel cus i love the sound it makes when you put your foot down! !amazed Link to post Share on other sites
kilokilla 0 Posted June 9, 2004 Report Share Posted June 9, 2004 lol no probs was just to much for me with me 600 miles a week the drone on 500 mile journey was to much although i agree it does sound awesome. Link to post Share on other sites
Geastb 0 Posted June 9, 2004 Author Report Share Posted June 9, 2004 I only do about 150 miles a week to work and about 300 miles of just driving about enjoying the sound! lol Link to post Share on other sites
