gazbrook 0 Posted May 11, 2004 Report Share Posted May 11, 2004 Hi,I will (hopefully) have my car finished by this Sat, i chipped it once when i had just a stainless exhaust, now i have had other mods , 3.0 conversion etc i have been told i need it chipping again, i am $&@% off , this is because i will probably have too lean a fuel mixture so i have been told. Is there any way around it , ie a rolling road tune or one of those add on fuel pressure regulator jobbys?? ~ Link to post Share on other sites
FishWick 21 Posted May 11, 2004 Report Share Posted May 11, 2004 If you plan on numerous mods, you're better off with a reprogrammable piggy-back chip, otherwise the standard chips used for rechips are only writeable once unfortunately. The MAF sensor won't be able to adapt to the extra air the 3.0 is pulling in and the preset fuelling at WOT won't be rich enough either. Link to post Share on other sites
Hiten 0 Posted May 12, 2004 Report Share Posted May 12, 2004 I've just had a 3.0 conversion done and all I did was to up the fuel pressure to 5 bar on my adjustable pressure regulator(FSE). Link to post Share on other sites
gazbrook 0 Posted May 12, 2004 Author Report Share Posted May 12, 2004 Did adjusting the Fse make your car run better?? Still might have a problem with the extra air been pushed through Link to post Share on other sites
ingham 5 Posted May 12, 2004 Report Share Posted May 12, 2004 uping fuel pressure wont make much more fuel ,beware ! Link to post Share on other sites
gazbrook 0 Posted May 12, 2004 Author Report Share Posted May 12, 2004 does anyone know if it will do any harm running on a lean amount of fuel or will it just sacrifice a bit of performance till i get it chipped? Link to post Share on other sites
jcorallo 0 Posted May 12, 2004 Report Share Posted May 12, 2004 What ECU map are you running? 2.9?its not something you can theorise about on a forum thread really - you really need it checking and mapping if necessary, on a RR.You could say that for the extra air its pulling in (~150cc?), its still within a safe margin of being so lean that it melts the pistons or causes bad knock. But you dont know till you get your wallet out and stick it on a RR and get a fuel curve.Personally, I reckon the ECU will cope with it during closed loop, but for WOT, you'll need to have upped the fuel pressure a bit just in case. 5.0bar might be too rich for the extra ~150cc added - but you jsut dont know, so if you want to be safe in the meantime, 5.0 seems like a good number....All theory..... get it mapped!Jules Link to post Share on other sites
gazbrook 0 Posted May 12, 2004 Author Report Share Posted May 12, 2004 My bird has just said for me to stop being such a tight arse and get it remapped, she said what is the point in spending thousands on an engine and being a tight arse when it comes to chipping it , so I HAVE BEEN TOLD!!! I'm definitely gonna get it remapped with a reprogrammable chip,cheers Link to post Share on other sites
Hiten 0 Posted May 13, 2004 Report Share Posted May 13, 2004 i had the fueling set up on grant motorsports rollers and seemed to run better at 5 bar. i'm running a standard 2.9 ecu but will eventually it re-mapped once the engine is run in. Link to post Share on other sites
