binliner 0 Posted May 11, 2004 Report Share Posted May 11, 2004 As above... the car is unlocked but the button just presses in like its still locked! any ideas on whats wrong? and more to the point what I could do to open it so I can fix it? Link to post Share on other sites
MarkGolf 6 Posted May 11, 2004 Report Share Posted May 11, 2004 If you can't possibly open it with the button, maybe get someone on the inside to push it while u pull from outside...If that doesn't work, climb in the boot, undo the screw in the recess handle bit, pull the plastic cover off, and find the pull for the lock and pull it to unlock the boot... if that doens't open it, then it'll seem that tailgate has jamed on somehow! Link to post Share on other sites
Guest Olly_K Posted May 11, 2004 Report Share Posted May 11, 2004 as mark says really, there should be a "rod", pull it left and then right to see if it will release the catch Link to post Share on other sites
binliner 0 Posted May 11, 2004 Author Report Share Posted May 11, 2004 yeah looks like I'll have to crawl in the boot... cheers guys Link to post Share on other sites
six appeal 53 Posted May 11, 2004 Report Share Posted May 11, 2004 I now the pin has fallen off on a few I've had to fix when the boot won't open. Link to post Share on other sites
binliner 0 Posted May 11, 2004 Author Report Share Posted May 11, 2004 what pin is that? Link to post Share on other sites
six appeal 53 Posted May 11, 2004 Report Share Posted May 11, 2004 Theres a pin/rod connecting to the lock to push it over on the central locking (Sorry Justin difficult to explain!) Link to post Share on other sites
jcorallo 0 Posted May 11, 2004 Report Share Posted May 11, 2004 Have you tried using the actual key to unlock the boot? Link to post Share on other sites
binliner 0 Posted May 11, 2004 Author Report Share Posted May 11, 2004 yeah that doesnt work either Link to post Share on other sites
six appeal 53 Posted May 11, 2004 Report Share Posted May 11, 2004 Definately sounds like the pin/rod then Justin, it connects the key end to the actual lock part, via the central locking mechanism! Link to post Share on other sites
