Caddyslammed 16 Posted February 11, 2006 Report Share Posted February 11, 2006 my drivers side front electric window does not quite work correctly, just wondering if anyone knows what is up? it goes all the way down fine, but on the way up it stops about 2 thirds of the way up and then goes all the way down again, so to get it to go right up again i have to keep pushing the up button quickly till it is all the way up, pain in the arse!!, can anyone help please? Link to post Share on other sites
stockers 1 Posted February 11, 2006 Report Share Posted February 11, 2006 it proberbly needs the runners greased, take the door card off and grease all the metal bits the window uses to go up and down. Link to post Share on other sites
zuludong 0 Posted February 11, 2006 Report Share Posted February 11, 2006 berfore you go to the hassle of taking the door panel of try greasing up the seals at the sides of the windows with some sort of sylicone spray. Link to post Share on other sites
Caddyslammed 16 Posted February 11, 2006 Author Report Share Posted February 11, 2006 thanks you two, so both of you are saying it is going back down because of like a safety type thing, it is feeling resistance so it is going back down again, (could be a kids arm say), am i thinking correctly? Link to post Share on other sites
stockers 1 Posted February 11, 2006 Report Share Posted February 11, 2006 thats exactly right, mine did the same Link to post Share on other sites
Bee 0 Posted February 16, 2006 Report Share Posted February 16, 2006 Mine does it is well sometimes, pain in the arse. Link to post Share on other sites
shail 0 Posted February 17, 2006 Report Share Posted February 17, 2006 Mine does exactly the same. I've had the door card off and 'had a look'. Couldnt find anything obvious, but I did note that with the door card off it worked perfectly, so as above it might be worth greasing the seals. Link to post Share on other sites
Slim 0 Posted February 17, 2006 Report Share Posted February 17, 2006 Mine does that, nad has done ever since I accidentally pressed the down button when getting into the car when the window was covered in losts of bits of lumpy ice. My mechanic mate reckons I need a new window regulator. Link to post Share on other sites
28v6r 0 Posted February 18, 2006 Report Share Posted February 18, 2006 There are 2 possibilities here:1/ (Now I'm talking off the top of my head here..I think ) but if memory serves.. if you hold the drivers door lock on the full closed position i.e locked for 5-6 seconds you should see the the windows recalibrate themselves into position... I think that maybe all your problems.. is the safety mechanism needs reset.. try that OR2/ It sounds also that the control unit may be broken therfore a new regulator IS required.. !sad Link to post Share on other sites
Caddyslammed 16 Posted February 19, 2006 Author Report Share Posted February 19, 2006 i have just noticede that when i leave the window open and ignition off and press the keyfob to lock it up , the window always goes all the way up no problem! can anyone explain what this means, or does it narrow the problem down at all? i am going to grease the runners today anyway. Link to post Share on other sites
stockers 1 Posted February 19, 2006 Report Share Posted February 19, 2006 i think its just because the sensers will be linked to the ignition, if that is off the sensers will be off aswell Link to post Share on other sites
Caddyslammed 16 Posted February 19, 2006 Author Report Share Posted February 19, 2006 greasing the runners did not work, so i will try and get a motor and regulator off the bay as soon as Link to post Share on other sites
