Buzzark 0 Posted January 23, 2006 Report Share Posted January 23, 2006 I removed my MAF sensor for pre-emptive cleaning yesterday and stripped it apart to get a little suprise.While I'm sure I read it's supposed to have a hot wire sensor (made from platinum) I actually found what appears to be a pcb mounted surface film resistor (probably still made of platinum tbh).I've never seen one of these before, I had no idea they even existed.I'm also pretty sure I've read that the MAF sensor is supposed to heat to 1000.c briefly when you switch off the engine to burn off any deposits. There's no way one of these would be able to do that without melting.It's an OBDC 2 '97 model, maybe earlier models DO have a platinum hotwire sensor - anybody know?Oh, and although it was pretty clean, the throttle reponse it a little cripser following the cleaning. Link to post Share on other sites
bazz780 0 Posted January 23, 2006 Report Share Posted January 23, 2006 hi, may i ask what you cleaned it with?i remember seeing the MAF in my mk4 V5 and it was deffo a thin film that looked like transparent plastic, i also remember seeing a wire like sensor on one of the mafs on one of my VR's but cant remember which it was now, i think it was the 1995 N reg one. Link to post Share on other sites
mightyvr6 0 Posted January 23, 2006 Report Share Posted January 23, 2006 Early vrs (up to about 95) had hotwire mafs then they switched to the hotfilm maf. Link to post Share on other sites
Buzzark 0 Posted January 23, 2006 Author Report Share Posted January 23, 2006 hi' date=' may i ask what you cleaned it with?i remember seeing the MAF in my mk4 V5 and it was deffo a thin film that looked like transparent plastic, i also remember seeing a wire like sensor on one of the mafs on one of my VR's but cant remember which it was now, i think it was the 1995 N reg one.[/quote']I used a contact cleaner spray. Plastic safe and non-residue from Maplins.Thanks for the info guys, I was just curious. Link to post Share on other sites
FishWick 21 Posted January 23, 2006 Report Share Posted January 23, 2006 Yep, OBD2 MAFs are 4 pin 'hot film' and minus the preheat stage that the earlier 'hot wire' 6 pin MAFs have. Link to post Share on other sites
