Aux Water Pump Probs?!?
Hi All. Got back from work the other day to find out that my engine was ever so slightly cooked :@ . I think I've traced the problem to the themostat being buggered!. Got a new neuspeed low-temp one on order. So.....problem solved?? Nope... The second problem I have is that the aux water pump is stuck on permanently. I knew that it did stay on when the engine is hot to cut down on heat sink. However, I left the car overnight, and it was still running the morning after B) . I had to disconnect the engine loom to stop it. Once I reconnected it, the pump started again. I was wondering if the aux pump was controlled by a relay?? If so, where is it located? If it isn't, then I'm stumped ?! .
Any suggestions gratefully received peeps!!
Ta.
u didnt leave your lights on did you? i noticed that if i leave the lights on on mine' date=' even with the ignition off and the keys out that the pump still runs. switch the lights off and the pump stops.
That doesn't sound right either mate :-) Aux water pump should be on all the time the ignition is on or when the engine temperature dictates it necessary, ie after a hot run.
Just been out to start up the motor 10mins ago. Sure enough, as soon as I connected the wiring loom, i detected the sweet,sweet sound of the water pump. Disconnected the yellow gauge...no difference. So i had a look at the control box for the after-run. Problem solved methinks!! It looks like after the engine overheated, some of the coolant got dumped on the control box, as it's bloody soaked :@ . Took the fuses out, and the pump stopped :D . So I'm guessing there's a short where the loom connects to the box underneath. Now I've just got to get the damn thing dryed out!!
Another problem solved thanks to the VR6OC team.....Cheers Guys!!
Merry Christmas :)
