Whiney noise from n/s wheel
Hey everyone,
Was wondering if you could help me... was coming around a roundabout last night and could hearing a starnge sort of whirring whiny noise coming from the wheel. Came of onto a straight and it went away, seems to only be when i am turning.....
Could it be a wheel bearing? or the dreaded bushes :(
Advice apreciated
Matt
How do you figure?? CV joints **Click** not whine. Whine is more like a bearing, although it would be more of a drone as opposed a whine, seeing as its a press type bearing and not taper row... To Test a CV joint is to put the car into a figure 8 and listen if it clicks then you know its a CV joint, if however there is no clickin' then I'd say is more liable to be a bearing.... ;):D
