FAO: Binliner RE: Dump valve
M8, in your how much does is it worth thread, you've indicated you got a dump valve for your charger.
is this a 'dump', valve which shoves air to atmosphere before the tb (in the charge intake piping). Or is it a recirc valve which recircs the air back after the maf (into the intake pipes before the charger).
if it's dump valve i'd be interested if you have any running problems, dumping metered air to atmosphere.
(interested becuase dump valves sound so good)
i assumed' date=' the zr2 is generally quiet :). I do get a bit of wierdness changing gear, its like a hiccup. maybe a dv will help?
lol why would you assume that?!
I've obviously not heard mine from the outside but I know minty's sounded like a small jet taking off as it went past!
