volkswag0nvr6 0 Posted July 13, 2005 Report Share Posted July 13, 2005 about a week ago she cut out. and wouldn't start again (no spark). since then i have changed the coilpack and the hall sender. and still nothing..is there anything else i can check before i take it to a garage? thanks Link to post Share on other sites
mightyvr6 0 Posted July 13, 2005 Report Share Posted July 13, 2005 Give the crank position sensor a good clean. It's on the right hand side of the block next to the oil cooler. Link to post Share on other sites
volkswag0nvr6 0 Posted July 13, 2005 Author Report Share Posted July 13, 2005 ok cheers mate will give that a try.. Link to post Share on other sites
volkswag0nvr6 0 Posted July 13, 2005 Author Report Share Posted July 13, 2005 found my problem.. 3 wires in the main engine loom have been cut some how and possibly shorted out.i have crimped them together, but she still wont startdo you think this could have dammaged my ecu?cheers Link to post Share on other sites
mightyvr6 0 Posted July 13, 2005 Report Share Posted July 13, 2005 Do you get any click from the ecu relay? Link to post Share on other sites
volkswag0nvr6 0 Posted July 13, 2005 Author Report Share Posted July 13, 2005 yes when i turn the ignition on there is a click from the ecu relay.. does that mean the ecu is ok?if i was to take just the ecu down to vw would they be able to check it? Link to post Share on other sites
mightyvr6 0 Posted July 13, 2005 Report Share Posted July 13, 2005 Mine did that and the ecu was knackered. What number is the relay? Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 just had a closer listen, when i turn the ingnition on there is a clicking noise. but i don't think it is coming from a relay. but since then i have checked for power at the eco plug that goes to the coilpack and i have power there. aslo checked for power at the cam sender and that is fine.so i think it is safe to say that it is not the ecu.. i hope. i have been the crank sensor but if that was gone would it cause me not to have a spark?thanks Link to post Share on other sites
Eat this 2 Posted July 14, 2005 Report Share Posted July 14, 2005 u sure the fuel pump is working?? Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 yeah got fuel but no spark.. Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 I'm pretty sure that if the crank sensor is dead you don't get spark or fuel. Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 having trouble finding the crank sensor, would it be near the coil pack somewhere? Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 it's on the front of the block on the right hand side of the oil cooler. Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 ok think i have found it does it have 3 plugs going to it? Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 No, that's the thermostat housing. Go lower down. It's a single cable going into the block held in place with a single allen key bolt. Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 think i am going blind lolcan't see it anywherethanks for your help Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 It's the cable with the yellow tag in the pic: Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 nice one. cheers for that mate,will take it off and give it a good clean. looks like i will have to take the front end off to get to it tho. i know where there is a mk3 vr6 golf at a scrap yard near me (left hand drive) the crank sensor will be the same as the one on the corrado isnt it? Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 Yes the part should be the same. Link to post Share on other sites
volkswag0nvr6 0 Posted July 14, 2005 Author Report Share Posted July 14, 2005 nice, should save me a few quid.that is where i got the coilpack from.is there any other parts that would be worth robbing? Link to post Share on other sites
mightyvr6 0 Posted July 14, 2005 Report Share Posted July 14, 2005 The cam sensor, idle stabiliser valve, maf if they're cheap. Link to post Share on other sites
Bampson 0 Posted July 15, 2005 Report Share Posted July 15, 2005 where is that scrap yard mate ?? i have a few things i need to get ...afetr your finished of course !lol Link to post Share on other sites
volkswag0nvr6 0 Posted July 15, 2005 Author Report Share Posted July 15, 2005 just checked the crank sensor and it looks quite new, gave it a wipe down, all the surfaces were clean and free of rust.it is at red lodge. when i went last sat everything was ther apart fom the wheels and airbox. what are you after? Link to post Share on other sites
Bampson 0 Posted July 15, 2005 Report Share Posted July 15, 2005 is thaat near newmarket ?? Link to post Share on other sites
volkswag0nvr6 0 Posted July 16, 2005 Author Report Share Posted July 16, 2005 yes mate near newmarket.tryed another crank sensor today and still nothing. i know i said i had fuel but i don't, before i didn't take the fuel lines completey off and fuel p***** out, just took them fully off today and i am not getting any fuel. got power at the fuel pump but it is not running.so if i had no spark and no fuel it would suggest that the ecu could be knackered... Link to post Share on other sites
