Yes it can. I've done it in mine - 2.9 corrado block but with my original coil pack instead of the dizzy. IIRC you just need to use your (coilpack) wiring loom etc... I also kept the maifold and throttle body from my 2.8.
If you've got the two engines side by side then it's relatively straight forward but there are wiring issues to overcome.
To use the coilpack on a dizzy engine, you need:-
The cam cover end plate
Cam sensor with it's plug and loom
Coilpack with it's plug and loom
Coilpack HT leads
You might need the ECU aswell as I'm not sure if the dizzy ECUs have the software for cylinder selective timing or not, which the coilpack engines use.
The wiring looms then terminate into the big twist-lock connector......and again, I don't know how the dizzy and CP engines differ there....
Cheers. I think it may be sorted anyway, may have a coil pack engine?? Not 100% I'll need it yet anyway.
Kev, whats going on with the C forum mate? I havent been able to log in all day. (stanbates) Spoke to Gav (h100vw) earlier, and he cant either.
