volkswag0nvr6 0 Posted July 3, 2005 Report Share Posted July 3, 2005 hi peoplefor the last couple of days my car has been hesertating under load. like the HT leads were breaking up.and last night it cut out.. now it wont start.. it is a mk2 golf with a 2.9 corrado engine in it (the coilpack one)what could it be? Link to post Share on other sites
badboyV6 4 Posted July 3, 2005 Report Share Posted July 3, 2005 Could be a mulitude of things bud, try hall sender, and check to see if your coilpack is arcing would be 2 things to check. Sounds a lot like the coil pack has given up- test it first - if it is then try Ford for a new one- its a lot cheaper than buying the same part from VW (They used it on the Galaxy VR6) Link to post Share on other sites
Nerih 0 Posted July 3, 2005 Report Share Posted July 3, 2005 if it were a mk3 i'd say get fault codes read, can you do this with yours too? Link to post Share on other sites
volkswag0nvr6 0 Posted July 3, 2005 Author Report Share Posted July 3, 2005 how can you check the coilpack? and where is the hall sender located?cheers Link to post Share on other sites
mightyvr6 0 Posted July 3, 2005 Report Share Posted July 3, 2005 Pull the leads and make sure each one is sparking. Use a sparkplug in each to test for spark. The hall sender (cam sensor) is right above the coilpack. Link to post Share on other sites
volkswag0nvr6 0 Posted July 3, 2005 Author Report Share Posted July 3, 2005 ok i will give that a try tomorrow when i get home from work.. i did try two of the leads for a spark and there was nothing there. are hall senders expensive, if not would it be worth me changing it so i know it is not that..thanks Link to post Share on other sites
volkswag0nvr6 0 Posted July 4, 2005 Author Report Share Posted July 4, 2005 is there a way of testing the coil pack off the car? would like to know for sure before i buy one. found one for Link to post Share on other sites
