boab3 164 Posted November 8, 2016 Report Share Posted November 8, 2016 Can anyone shed some light.Since im charging my golf im wanting to keep my mk2 fuel tank.Im looking at keeping lift pump in tank and upgrading main fuel pump.does anyone know what pumps fit the accumulator box on the mk2 or know the dimensions of the oe pump.cheers Link to post Share on other sites
Golf_crazy 2 Posted November 9, 2016 Report Share Posted November 9, 2016 Hi I was in a similar situation a couple of years back. Most people were actually removing the main pump under the car and installing a high flow uprated in tank pump which apparently works well. But like you I didn't want to do that if you search online there are some direct replacement pumps (Bosch 044 I believe) but depends what fuel pump (mk2 model) you started out with. I started out with an 8V digifant before I did my VR6 conversion and found that a company in the US did a nice upgrade link below. Don't know if they still do it also when I purchased it pound was a lot stronger so made sense. https://store.034motorsport.com/blog/fuel-pump-install-mk2-volkswagen-high-output-kit/ Hope this helps. boab3 1 Link to post Share on other sites
boab3 164 Posted November 9, 2016 Author Report Share Posted November 9, 2016 Hi I was in a similar situation a couple of years back. Most people were actually removing the main pump under the car and installing a high flow uprated in tank pump which apparently works well. But like you I didn't want to do that if you search online there are some direct replacement pumps (Bosch 044 I believe) but depends what fuel pump (mk2 model) you started out with. I started out with an 8V digifant before I did my VR6 conversion and found that a company in the US did a nice upgrade link below. Don't know if they still do it also when I purchased it pound was a lot stronger so made sense. https://store.034motorsport.com/blog/fuel-pump-install-mk2-volkswagen-high-output-kit/ Hope this helps. Thanks for the information ill go and have a read. Link to post Share on other sites
