psilosimon 8 Posted October 19, 2016 Report Share Posted October 19, 2016 My clutch has started being weird sometimes in traffic, it does not fully return, have to sort of hook your foot around the pedal then it will be alright for ages. What's that about? recently fitted a new slave cylinder because I though that may be playing up. Link to post Share on other sites
senorfancypants 0 Posted October 19, 2016 Report Share Posted October 19, 2016 You might just have to bleed the system again. I had this problem when I bought my car. I replaced the slave cylinder, bled it about 5 times and she was fine right after, no more problems. And idk if this helped me but when I was pumping the clutch I held the brake pedal down too since it is a shared Reservoir. Link to post Share on other sites
VR6Pete 1,455 Posted October 19, 2016 Report Share Posted October 19, 2016 Did you bleed it with an Eezibleed? Sounds like there is air trapped, it's a bit of a bad design but bled properly should be ok. I also had similar issue where peddle wasn't fully returning and ended up was a small nic in the seal, but if it's new then would suggest to bleed and push out any remaining air Link to post Share on other sites
