boab3
Vr fuel tank wanted
I have one that you can have but no pump in it?
Cheers i might have to take you up on this as i had bought one from Stowmarket guy sam on here kindly picked it up for me and wrapped it up i organised a courier and now courier has lost the tank. Fuming never even made it out of Stowmarket and to make matters worse not willing to compensate anything.
Did you manage to get the parts you need ? I have a mk3 VR6 '98 that is slowly being stripped of parts for my Vento, but I shouldn't need any of the fuel tank parts or pipes etc. The car is at my work (just outside Edinburgh), so could check the condition of stuff tomorrow when I'm back in.
Thatd be great as ive got a mk2 16v pump im away to run but id prefer to have the mk3 tank as its easier to use.i can collect as im normally travelling the Edinburgh Glasgow areas with my job.cheers
The pipes etc don't look too bad, there is a bit of corrosion around the metal that crimps the rubber end ( that goes onto the filter) to the plastic pipe section - probably what you would expect of a car of that age.
you will find it hard to find one without a corroded filler neck! i have one buddy but am in south london, its got the vr6 4-bar fuel pump inside it ad not the 3-bar one, best to text me on 07773114069 :-)
