VR6CABBS 1,311 Posted March 15, 2016 Report Share Posted March 15, 2016 So as the title say's......... I just wanted to know if there was anyone out there who was using HEL braided hoses on there Brembo's on there MK3?? I need the length of the hoses that you had made if anyone can help. Hel wont guess the length. Any help would be greatly appreciated. Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 @ibs@Richierich37 Come on boys. You guys have Hel hoses. I'll post you a piece of string and a tape measure if need be. Sent from my iPhone using Tapatalk@ibs @ibs Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Sent from my iPhone using Tapatalk yinnyvr6, richierich37 and Bealieboy 3 Link to post Share on other sites
ibs 308 Posted March 26, 2016 Report Share Posted March 26, 2016 Hi cabbs I'm not running Hel lines. I ordered a set for the Leon Cupra R from Matt Lewis racing on ebay. Item number 401042113359. I remember the bolts that screw in to the caliper were not the right ones for some reason so they sent me out 2 fine pitch bolts separately. I would measure mine for you but I'm away for 2 weeks and the car is round my mates. Sent from my SM-N920C using Tapatalk Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Hi cabbs I'm not running Hel lines. I ordered a set for the Leon Cupra R from Matt Lewis racing on ebay. Item number 401042113359. I remember the bolts that screw in to the caliper were not the right ones for some reason so they sent me out 2 fine pitch bolts separately. I would measure mine for you but I'm away for 2 weeks and the car is round my mates. Sent from my SM-N920C using Tapatalk No worries pal. I'll take a llook at look at them shortly. Thanks again. Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Hi cabbs I'm not running Hel lines. I ordered a set for the Leon Cupra R from Matt Lewis racing on ebay. Item number 401042113359. I remember the bolts that screw in to the caliper were not the right ones for some reason so they sent me out 2 fine pitch bolts separately. I would measure mine for you but I'm away for 2 weeks and the car is round my mates. Sent from my SM-N920C using Tapatalk Have you connected the open end coupling straight into the side of the calliper pal or used a 90 degree bend? Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 And what are the two little hoses for? Haha. Sent from my iPhone using Tapatalk Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Hi cabbs I'm not running Hel lines. I ordered a set for the Leon Cupra R from Matt Lewis racing on ebay. Item number 401042113359. I remember the bolts that screw in to the caliper were not the right ones for some reason so they sent me out 2 fine pitch bolts separately. I would measure mine for you but I'm away for 2 weeks and the car is round my mates. Sent from my SM-N920C using Tapatalk Shouldn't our fitting be like this pal? Link to post Share on other sites
ibs 308 Posted March 26, 2016 Report Share Posted March 26, 2016 Shouldn't our fitting be like this pal? They will look like that. The kit from ML racing will have the bolt that screws into the caliper and 1 side of the long hose in their pic is a open ring which slots on the bolt before you screw into the caliper. So that makes it a 90 degree angle. The other end of the hose is the same as in ur pic above. The short hoses are for the rear calipers on a Cupra but they are no use to us on mk3's as ours have different ends I'm pretty sure. Sent from my SM-N920C using Tapatalk Link to post Share on other sites
ibs 308 Posted March 26, 2016 Report Share Posted March 26, 2016 Shouldn't our fitting be like this pal? They will look like that. The kit from ML racing will have the bolt that screws into the caliper and 1 side of the long hose in their pic is a open ring which slots on the bolt before you screw into the caliper. So that makes it a 90 degree angle. The other end of the hose is the same as in ur pic above. The short hoses are for the rear calipers on a Cupra but they are no use to us on mk3's as ours have different ends I'm pretty sure. Sent from my SM-N920C using Tapatalk Bealieboy 1 Link to post Share on other sites
ibs 308 Posted March 26, 2016 Report Share Posted March 26, 2016 Get a nice set of discs and pads to go with the calipers and the brakes will be absolutely awesome. I've got ebc ultimate discs and ferrodo ds2500 pads and they have saved me many times 😉 Sent from my SM-N920C using Tapatalk VR6CABBS and Bealieboy 2 Link to post Share on other sites
richierich37 236 Posted March 26, 2016 Report Share Posted March 26, 2016 Yup but I've no idea what to measure! Lol Bealieboy 1 Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Get a nice set of discs and pads to go with the calipers and the brakes will be absolutely awesome. I've got ebc ultimate discs and ferrodo ds2500 pads and they have saved me many times Sent from my SM-N920C using Tapatalk Yeah I've got 323mm EBC disc's and Brembo pads. ibs and Bealieboy 2 Link to post Share on other sites
VR6CABBS 1,311 Posted March 26, 2016 Author Report Share Posted March 26, 2016 Yup but I've no idea what to measure! Lol Come on Richard. I only need the length of that purple hose from where it bolts into the back of the caliper and to the other end where it couples with the brake line on the inner leg. Just the full length of the Hel hose mate. Easiest way is to use a piece of string or wire pal. Bealieboy 1 Link to post Share on other sites
Rysa@VRT 31 Posted March 26, 2016 Report Share Posted March 26, 2016 Running seat Leon 323mm front Discs with the hel lines . Link to post Share on other sites
VR6CABBS 1,311 Posted March 27, 2016 Author Report Share Posted March 27, 2016 Running seat Leon 323mm front Discs with the hel lines . How does the hose fit the back of the caliper pal? Is it in the middle like the Cupra Brembo? They actually sell the Hel hoses for the Porsche caliper for the vr6 on eBay but not the Cupra Brembo. Link to post Share on other sites
VR6CABBS 1,311 Posted March 27, 2016 Author Report Share Posted March 27, 2016 How does the hose fit the back of the caliper pal? Is it in the middle like the Cupra Brembo? They actually sell the Hel hoses for the Porsche caliper for the vr6 on eBay but not the Cupra Brembo. Are your fittings like this? Link to post Share on other sites
Rysa@VRT 31 Posted March 27, 2016 Report Share Posted March 27, 2016 21 hours ago, VR6CABBS said: Are your fittings like this? That is exactly what they are like and fitting is centre on caliper . Hope this helps Link to post Share on other sites
VR6CABBS 1,311 Posted March 27, 2016 Author Report Share Posted March 27, 2016 That is exactly what they are like and fitting is centre on caliper . Hope this helps You don't fancy measuring the length of the hoses for me do you mate? Link to post Share on other sites
Rysa@VRT 31 Posted March 27, 2016 Report Share Posted March 27, 2016 I'll do it Tuesday for you mate Link to post Share on other sites
VR6CABBS 1,311 Posted March 27, 2016 Author Report Share Posted March 27, 2016 I'll do it Tuesday for you mate I appreciate it mate. Desperate to order my hoses from Hel but they won't guess on the length. Nice one mate. Rysa@VRT 1 Link to post Share on other sites
VR6CABBS 1,311 Posted March 29, 2016 Author Report Share Posted March 29, 2016 A big thanks to @Rysa@VRT for his help with the measurements of the Hel braided hoses. There ordered and should be here in a couple of days. I know what I'll be doing this weekend. Sent from my iPhone using Tapatalk Rysa@VRT 1 Link to post Share on other sites
