six appeal 53 Posted January 29, 2016 Report Share Posted January 29, 2016 Hi guys, Got a little issue with my Supercharged VR6 at the minute. It's an OBD2 VR6 with Low Comp re-built engine running a Vortech Charger. Having a few issues with the Catch can that comes with the kit as it keeps either leaking or blowing the hoses off! Causing the car to run rough and not idle well when it does.Currently I run the Catch can in the place of the PCV valve (this has been removed) with one end of catch can connected to the cam cover breather outlet and the other connected to the air inlet pipe between the charger and the throttle body. I'm looking at getting a metal catch can and fittings (as opposed to the crappy plastic one supplied with the kit) as hoping this will remove any small air leaks. What do you guys find best to run? Metal catch cans? Catch cans with the PCV? Anyone got pics of their set up please? Thanks in advance, Simon. Ps. It runs a Shrick too, but don't think that should matter, more interested in what others are running. VR6Pete 1 Link to post Share on other sites
VR6Pete 1,455 Posted January 29, 2016 Report Share Posted January 29, 2016 Here's my setup:Later decided fit PCV:I opted for a vented setup:What clamps you running? six appeal 1 Link to post Share on other sites
six appeal 53 Posted January 29, 2016 Author Report Share Posted January 29, 2016 Thanks Pete, that's a big help. So does that go from the cam cover to the PCV then a pipe onto the catch tank which then vents to atmosphere Pete? You running a charger now? Thinking about it and chatting to to a mate, I think it maybe the fact its taking a pipe from between the charger and throttle body that's my issue as that's effectively at least 12psi which is then back feeding and pressurising my catch tank and the cam cover/top of the head. More pics of other set-ups would be great Simon. Link to post Share on other sites
bennyk 1,238 Posted January 29, 2016 Report Share Posted January 29, 2016 I just vent straight to atmosphere under the car, runs fine like that and I don't get any bad smells or fumes. six appeal and D11PS 2 Link to post Share on other sites
D11PS 146 Posted January 30, 2016 Report Share Posted January 30, 2016 I vented my V9 atmospherically aswell a straight pipe under the car six appeal 1 Link to post Share on other sites
VR6Pete 1,455 Posted January 30, 2016 Report Share Posted January 30, 2016 Thanks Pete, that's a big help. So does that go from the cam cover to the PCV then a pipe onto the catch tank which then vents to atmosphere Pete? You running a charger now?Thinking about it and chatting to to a mate, I think it maybe the fact its taking a pipe from between the charger and throttle body that's my issue as that's effectively at least 12psi which is then back feeding and pressurising my catch tank and the cam cover/top of the head.More pics of other set-ups would be great Simon.Sure does mate. Running. Vortech V1 I'm installing at the moment. Stage 2. Nearly there now. If I have any issues with fumes I will vent the catch tank under the car. Just don't want any oil deposits dripping venting straight to air without a can. six appeal 1 Link to post Share on other sites
dom.joy 87 Posted January 30, 2016 Report Share Posted January 30, 2016 Thanks Pete, that's a big help. So does that go from the cam cover to the PCV then a pipe onto the catch tank which then vents to atmosphere Pete? You running a charger now? Thinking about it and chatting to to a mate, I think it maybe the fact its taking a pipe from between the charger and throttle body that's my issue as that's effectively at least 12psi which is then back feeding and pressurising my catch tank and the cam cover/top of the head. More pics of other set-ups would be great Simon.I reckon that's your issue. I'm venting mine to atmosphere on my V1. Only get slight fumes if I'm sat still in traffic six appeal and VR6Pete 2 Link to post Share on other sites
Solution six appeal 53 Posted January 30, 2016 Author Solution Report Share Posted January 30, 2016 Thanks guys, I'm on Nights this weekend.But managed to spend an hour or 2 looking over the car today, and playing with it. Blocked the hose from the inlet pipe between charger and throttle body first. (Hoping to source/make a pipe without this hole in it eventually once I know it runs ok) Have then run the Head cover breather through the catch can and then dumping from there to atmosphere as suggested. This seems to run a lot nicer so far. Planning on putting the PCV and associated pipes back on it, as have 2 brand new Genuine VW PCV's in the garage, then through the Catch can and to atmosphere to give it a more original look to it, as having that plug and small pipe dangling there has always bugged me! Hopefully that should sort all the issues. Sorry didn't get time to get pics as I needed to get to sleep! Thanks again for all your help/pics. Simon. Bealieboy and VR6Pete 2 Link to post Share on other sites
VR6Pete 1,455 Posted January 31, 2016 Report Share Posted January 31, 2016 Sounds good mate! Do you still work for Mars then? six appeal 1 Link to post Share on other sites
six appeal 53 Posted February 6, 2016 Author Report Share Posted February 6, 2016 On 31/01/2016 at 9:01 PM, VR6Pete said: Sounds good mate! Do you still work for Mars then? No mate I left there over 8 years ago! Work for a Large Data Centre Company now as the Facilities Engineer. Simon. VR6Pete 1 Link to post Share on other sites
