24v turbo advice needed
hi guys im going to be using this page as an advice/build thread for a turbo build for my jetta coupe
the car in question
10277043_10152130570550945_3401294052227
as you can see i've already converted it to 24v
i've decided on a power goal of 400bhp, i want the thing to still be useable for going to the shops etc
the current  spec of what i want/have is
2.8 bde lump with only 60k (have)
mk5 r32 cylinder head with mk4 cams and chains etc (have)
1mm head spacer
q7 big end bearings
arp rod bolts
modified timing chain tensioner?
eurowise shallow sump
mk5 r32 oil pump
yes i know my list is missing vitals like turbo etc but i want to concerntrate on doing it in stages
so my couple of questions to start with is,
im sure i have seen somewhere modified guides or tensioner for use with headspacers, who sold these?
anyone got the part number for q7 rod bearings?
thanx in advance
barry
ARP and a spacer will comfortably handle that amount of power if your engine is sound - tensioner depends on the thickness/compression of the set up;
http://www.vr6oc.com/forum/topic/41681-vr6-turbo-question-spacer/
Both thickness and number are different for the VR/R32 studs, this is a very low boost set-up/goal so why fork out for things like R32 head when it's not needed?
P.S. Someone asked me to price up the main parts for such a set up but at a more reasonable cost than is usually found - £1500-2k or so for the main parts if you're interestd in what I suggested?
Stick with the 2.8, cams/ecu functions etc are all same BDE/BFH, you'll need 034's stud set, spacer ARP, consumables - good to go!
Edited by RBPE
i got the r32 head for a steal hence why im using it
Yah but now you've got to fork out for modifying it, the money would've been better spent on parts for what you have - even swirl/porting basic info isn't really needed until after 650hp on these engines.
Quick lesson in headology for these engines - i.e. VR/R32:
