Eat this 2 Posted June 3, 2005 Report Share Posted June 3, 2005 iv change the arb drop links and just had the suspension top mounts changed but iv STILL got a very annoying clunk when locking the steering over any sugestions appreciated ps nothing seems to be loose Link to post Share on other sites
Eat this 2 Posted June 4, 2005 Author Report Share Posted June 4, 2005 anybody?? Link to post Share on other sites
acf8181 0 Posted June 4, 2005 Report Share Posted June 4, 2005 wishbone bushes? or ball joints? Link to post Share on other sites
VR6Rich 3 Posted June 4, 2005 Report Share Posted June 4, 2005 I know Warren had a clonking problem on his syncro which he thinks is to do with the rack now. Link to post Share on other sites
VR6Pete 1,455 Posted June 4, 2005 Report Share Posted June 4, 2005 I had a clunking noise, it was probably to do with my wisbone bushes being split, had em replaced, now is fine.could be CV joints though? Link to post Share on other sites
Eat this 2 Posted June 4, 2005 Author Report Share Posted June 4, 2005 were 80% sure its either track rod ends or ball joint the problem is theres no obvious play anyway its rock solid Link to post Share on other sites
badboyV6 4 Posted June 4, 2005 Report Share Posted June 4, 2005 Ok, just to let you know..... I have a knocking that appears to only happen when i go slowly and turn on an uneven surface... its quite loud and you can feel it through the pedals, i was convinced it was suspension however the local VW garage checked the suspension and nothing seems to be wrong- there is no play in my steering either- Ive had a good listen and it seems to be either one of 2 things- Eitther its the lower CV joint on the steering rack- about 150 quid, or it could be the adjustment needs tightening on the rack as ive just found out from the Bentley manual, as it desribes you will hear a knocking (which i do) Im going to try this first and if not its the joint... Get some one to move the rack from side to side with the engine off and have a listen where the rack meets the pinion.... Link to post Share on other sites
Eat this 2 Posted June 4, 2005 Author Report Share Posted June 4, 2005 Ok' date=' just to let you know..... I have a knocking that appears to only happen when i go slowly and turn on an uneven surface... its quite loud and you can feel it through the pedals, i was convinced it was suspension however the local VW garage checked the suspension and nothing seems to be wrong- there is no play in my steering either- Ive had a good listen and it seems to be either one of 2 things- Eitther its the lower CV joint on the steering rack- about 150 quid, or it could be the adjustment needs tightening on the rack as ive just found out from the Bentley manual, as it desribes you will hear a knocking (which i do) Im going to try this first and if not its the joint... Get some one to move the rack from side to side with the engine off and have a listen where the rack meets the pinion....[/quote']that sounds almost identical to my clunk !dodge its not very loud but i can fel it through the car no play in the steering doesnt affect driving 1 iota il check the rack monday Link to post Share on other sites
badboyV6 4 Posted June 4, 2005 Report Share Posted June 4, 2005 Yeah mines gradually got a little worse- its feeling a little vague around the straight ahead but movement in the wheels is perfect) Yours may not be that but its definitely worth a shot mate. Have you got the bentley manual? Link to post Share on other sites
Eat this 2 Posted June 4, 2005 Author Report Share Posted June 4, 2005 no i dont have the maual Link to post Share on other sites
badboyV6 4 Posted June 4, 2005 Report Share Posted June 4, 2005 ah bugger- it shows you how to correct the play if theres a knocking coming frm inside th car- exactly like mine... there is like a diamond shapedmetal plate with three bolts in it- the mddle one being the adjuster... See if the noise is coming from there first - if it is pm me and ill write out what it says in the manual...... Link to post Share on other sites
Eat this 2 Posted June 6, 2005 Author Report Share Posted June 6, 2005 been on a ramp today there is NO play anywhere we even had a gentle go with a crow bar NOTHING is loose but he did mention the wishbone bushes r beggining to give up probably 98% left il see how it goes over a few weeks see if it gets worse Link to post Share on other sites
