Vince12v 20 Posted August 31, 2014 Report Share Posted August 31, 2014 Evening chapsRecently changed my coil pack, mass air flow sensor, plugs, and still have a misfire but now it's worse, no it's bogging down losin 2 pots, I'm thinkin it may be the cam sensor or the crank sensor?Any ideas? Link to post Share on other sites
Bealieboy 1,625 Posted August 31, 2014 Report Share Posted August 31, 2014 (edited) I'm sure crank sensor failure will make the engine cut out completely, not affect individual cylinders. Have you checked all leads are seated correctly on the coil and plugs. Did you replace the coil etc due to the misfire? Edited August 31, 2014 by Bealieboy MJ Vr6 1 Link to post Share on other sites
Vince12v 20 Posted August 31, 2014 Author Report Share Posted August 31, 2014 Yea the old one was covered in cracks! All leads seated was the first thing I checked Link to post Share on other sites
Bealieboy 1,625 Posted August 31, 2014 Report Share Posted August 31, 2014 Ok, so that's coil and leads eliminated and also probs crank sensor. What next? Right, I googled it and came up with this....... Sounds like the coilpack, if you've lost 2 cylinders.There's three coils, so two cylinders go at a time with it.And I don't think a coil pack fail will show up on VAG-COM, either. (The engine will just notice the extra fuel in the exhaust and try to run it leaner on the remaining cylinders, I don't think it'll be able to directly tell that there's a misfire (or no-fire) on some cylinders. Could be wrong, but... Link to post Share on other sites
VR6Pete 1,455 Posted September 3, 2014 Report Share Posted September 3, 2014 Which plugs are not firing? Link to post Share on other sites
Bo Beachum 0 Posted September 5, 2014 Report Share Posted September 5, 2014 Hey my 2001 jetta vr6 the inside lights and power windows also the automatic door locks quit working i check the fuses all good even the relay are good what's my problem Link to post Share on other sites
Bo Beachum 0 Posted September 5, 2014 Report Share Posted September 5, 2014 Sorry don't mean to change subject just trying to figure this oity Link to post Share on other sites
Bo Beachum 0 Posted September 5, 2014 Report Share Posted September 5, 2014 K well I guess I figure it out thanks for tha help Link to post Share on other sites
