sharki 2 Posted June 13, 2014 Report Share Posted June 13, 2014 is it realy worth me putting one on my airbox? Its standard airbox with 2.9inlet. The trumpet has been removed from the airbox i wanted to know before i butcher the bottom of the air box.Engines a 2.8 obd2 Link to post Share on other sites
abvsean 32 Posted June 15, 2014 Report Share Posted June 15, 2014 Think they move them due to heat soak but unsure how much difference it does make.I swapped mine from a 1.8t but modified the inlet manifold to keep it in the existing position. Link to post Share on other sites
Cespo500 1 Posted June 17, 2014 Report Share Posted June 17, 2014 Run a brake hose to through box and through the fender sharki 1 Link to post Share on other sites
Therusterman 59 Posted June 19, 2014 Report Share Posted June 19, 2014 I thought there kind of already was a cold air feed running from the air box into the side of the wing? Link to post Share on other sites
Cespo500 1 Posted July 10, 2014 Report Share Posted July 10, 2014 There is, but very small Link to post Share on other sites
sharki 2 Posted July 13, 2014 Author Report Share Posted July 13, 2014 Run a brake hose to through box and through the fenderthis is what i ment in the 1st post. Thanks! Link to post Share on other sites
