isobarboy 25 Posted April 25, 2014 Report Share Posted April 25, 2014 Ive got the dash out and steeringwheel off etc. But I now cannot acces the housing unit to remove my faulty matrix.Im stuffed as I dunno where to go from here and really dont wsnt to take it to a garage (Someone please help ne on what I should do from here to get the housing out so I can see the internals to fix my leak.Thank you!! this one is inside as far I can see Link to post Share on other sites
VR6Pete 1,455 Posted April 25, 2014 Report Share Posted April 25, 2014 Hi mateAs you are a club member you can access the knowledge vault forum section and view our guide on replacing your heater matrix Pete Link to post Share on other sites
Lukey. 381 Posted April 25, 2014 Report Share Posted April 25, 2014 The KB guide gives you all you need to get it out, I'll give you a tip though, undo the dash bar bolts in the door shuts and it'll give you a good but more wiggle room. Link to post Share on other sites
isobarboy 25 Posted April 25, 2014 Author Report Share Posted April 25, 2014 Hello. Lukey if youre referring to the two bolts either side within the door shutsive already removed them. The vault, gosh I forget these perks! Thank you ill check it out.Ill keep you posted Link to post Share on other sites
isobarboy 25 Posted April 25, 2014 Author Report Share Posted April 25, 2014 Just to ask, do you have a quick link to this guide? Thank you. Link to post Share on other sites
isobarboy 25 Posted April 25, 2014 Author Report Share Posted April 25, 2014 (edited) Found the guide. Thank you this shoukd do jusy the trick!! Any ideas on where to get akk the foam Inserts. Mine have rotted away? Edited April 25, 2014 by isobarboy VR6Pete 1 Link to post Share on other sites
Lukey. 381 Posted April 26, 2014 Report Share Posted April 26, 2014 dunelm Link to post Share on other sites
isobarboy 25 Posted April 26, 2014 Author Report Share Posted April 26, 2014 The guide says remove 5 nuts altogether under the hood. I for the life of it cannot see this nut near the abs pump. Is It hidden under the air con unit? As I pulled the life outa the unit in the car and it definateky seems stuck at one point in the same area as this elusive nut??Thanks Link to post Share on other sites
isobarboy 25 Posted April 26, 2014 Author Report Share Posted April 26, 2014 Rifht ive found that elusive nut..... are VW taking ze piss! Its literally been buried by the air con. Wish i didnt have air con now lol. Need a 5 year old who had 3 ekbow joints and abnornally long arms to get to it.Im genuinly stumoed how to get that offf??Suggestions would be a god send 0:)Kind regards all VR6Pete 1 Link to post Share on other sites
