wondering what is the best rear brakes people are using on the VR6's n turbos ...
been toying with the ide of modifiying a pair of hubs to work/ fit but wouldnt mind saving myself some time if anyone has any bright ideas...  ideally i wanted to run 345mm r32 front n rear brakes ..  ive just purchased a 312mm edition 30 brakes ...  the discs are scrap as there 5 x 112 but obv 5x 100  will be fine as there still 312mm  dia...  i kno i need the 6mm  plate to centralize the caliper ..  so its just rears im left with to sort out ...
 come on lads whos running what ..  whats works n what doesnt ...
Mk4 rears. Much lighter and won't sieze anywhere near as much if ever. Bolts straight onto your mk3 carriers and discs but your better off buying the goodridge hose conversion (other brake hose manufacturers are available)
Not much need for massive discs on the rear as there isn't much weight in the back of a golf.
I will be sorting my rear discs and calipers as they are looking a bit tired, not looked into it too much ATM as it's further down in the to do list, but reading this is interesting, so mk4 rear calipers will bolt straight on without having to buy or change anything else (apart from the hoses which I was going to do any way) so what's the difference between the two, as I was clean and paint the calipers and put new discs and pads on
Apparently the difference is the mk4 is Ali where as the mk3 is steel and the mk4 is not prone to seizing . I have read somewhere about a conversion using bigger discs on the rear BUT as the mk3 uses a taper bearing on the rear I don't fully understand how they work it
This, if you want a lesson in how little the rear brakes do, next time it is wet, unplug your abs and go for a drive, you can swap ends real easy.
I should elaborate, if youre obd2 the abs sorts out the rear proportioning, disabling this makes the rears lock immensely easily, this is because the rears do hardly a thing.
Edited by Lukey.
See I thought about converting the rear myself to run different hubs .. I even looked at using a mk4 rear frame .. U ever ran the polo stubs mike? Is there much of a size difference in the mk4 discs compared to the mk3? I was just gonna what you said , mk4 caliper, drilled n grooved disc n braided hose .. Wanna get something sorted soon
  • 1 year later...
Just a quick question as didn't want to start a new thread
My rear calipers are shot so which mk4 calipers do I need and how about bolts and hand break cable?
Do I still use the mk3 rear discs and pads?
Best place to get new calipers? Vw/tps?
I'm get black diamond to do me all 6 braided brake hoses to fit
Some new brake fluid 5.1 or rbf600 stuff?
Is there anything els
Mk4 gti callipers will be a direct fit with mk3 carriers ,discs and pads ,handbrake cable also fits in the same way as original ,,only thing that changes is that the hose connections are banjo type ,goodridge do a conversion hose for this ...very simple job
