4 motion power loss no faults
Hi guys as titled I have a 02 4 motion in which started off as a small hesitation at low rpm and now has no low down power at all, no fault codes at all apart from one in the abs controller which just said ecm connector. After spending weeks on it I'm now stumped. Ive checked absolutely everything in mvb's and all readings are good, there are no air leaks and the cats are in perfect condition albeit white and a bit too clean which would suggest a lean mixture. All ignition coils, fuel filter and air flow meter are new. The car starts and runs perfectly with no misfires. Any help would be appreciated
Hi buddy just checked the readings in mvb 32 after a good drive and are as follows
On idle bank 1 short term -3.12 to 4.69 fluctuating
Long term 0.78 fixed
Bank 2 short term -3.12 to 3.12 fluctuating
Long term 0 fixed
At 3000 rpm at stand still
Bank 1 short term 0.78 to 4.61
Bank 2 short term -3.12 to 0
Long term 0 fixed
All figures show as percentages. Any light shed on these figures would be appreciated thanks
Hi mate I got a 03 4mo and its showing very similar symptoms ive got suspicion on my cat being blocked so am looking to decat it and hoping will cure it because ive given full service and Changed all coils and plugs and checked air flow sensor aswell only thing left is cat funny thing is had same issue on my mk3 highline lol
Hope it helps and if you find a cure let us know plz
Any of you guys checked the change over valve on the inlet is working and moving when revd hard? just atought!
  • 2 months later...
