DMARK 0 Posted March 4, 2014 Report Share Posted March 4, 2014 Hi guys as titled I have a 02 4 motion in which started off as a small hesitation at low rpm and now has no low down power at all, no fault codes at all apart from one in the abs controller which just said ecm connector. After spending weeks on it I'm now stumped. Ive checked absolutely everything in mvb's and all readings are good, there are no air leaks and the cats are in perfect condition albeit white and a bit too clean which would suggest a lean mixture. All ignition coils, fuel filter and air flow meter are new. The car starts and runs perfectly with no misfires. Any help would be appreciated Link to post Share on other sites
UnitedMotorsport 55 Posted March 4, 2014 Report Share Posted March 4, 2014 What is in measure block 32 after a good drive? Link to post Share on other sites
DMARK 0 Posted March 4, 2014 Author Report Share Posted March 4, 2014 On idle or whilst driving? Strangely enough it only lets me read data through basic settings I'm using launch x431 master with the latest update Link to post Share on other sites
UnitedMotorsport 55 Posted March 4, 2014 Report Share Posted March 4, 2014 Either it doesnt matter. Basic settings is not the right thing to use. Link to post Share on other sites
DMARK 0 Posted March 5, 2014 Author Report Share Posted March 5, 2014 Hi buddy just checked the readings in mvb 32 after a good drive and are as follows On idle bank 1 short term -3.12 to 4.69 fluctuating Long term 0.78 fixed Bank 2 short term -3.12 to 3.12 fluctuating Long term 0 fixedAt 3000 rpm at stand still Bank 1 short term 0.78 to 4.61 Long term 0.78 fixed Bank 2 short term -3.12 to 0 Long term 0 fixed All figures show as percentages. Any light shed on these figures would be appreciated thanks Link to post Share on other sites
muj33b 0 Posted March 14, 2014 Report Share Posted March 14, 2014 Hi mate I got a 03 4mo and its showing very similar symptoms ive got suspicion on my cat being blocked so am looking to decat it and hoping will cure it because ive given full service and Changed all coils and plugs and checked air flow sensor aswell only thing left is cat funny thing is had same issue on my mk3 highline lolHope it helps and if you find a cure let us know plz Link to post Share on other sites
parki 2 Posted March 14, 2014 Report Share Posted March 14, 2014 Hi mate I got a 03 4mo and its showing very similar symptoms ive got suspicion on my cat being blocked so am looking to decat it and hoping will cure it because ive given full service and Changed all coils and plugs and checked air flow sensor aswell only thing left is cat funny thing is had same issue on my mk3 highline lolHope it helps and if you find a cure let us know plzAny of you guys checked the change over valve on the inlet is working and moving when revd hard? just atought! Nex 1 Link to post Share on other sites
muj33b 0 Posted March 14, 2014 Report Share Posted March 14, 2014 Hmmmmm nope I havent and cars in the garage anyways so will have a look maybe tomorrow hopefully thanks for that Link to post Share on other sites
MK4motionVR6 41 Posted May 23, 2014 Report Share Posted May 23, 2014 Good call parki... I was just about to ask the very same question...?Mk4motionVR6 Link to post Share on other sites
