Pashlipops 0 Posted May 2, 2005 Report Share Posted May 2, 2005 Hi thereHas anyone adjusted their Koni Sport rears when fitted to the car? Is it easy?TIA Link to post Share on other sites
ninja 0 Posted May 2, 2005 Report Share Posted May 2, 2005 If your talking about koni top adjustables then yes it's easy to adjust the damping whilst on the car.I normally remove the parcel shelf supports but it could possibly be done without even these being removed.If you're talking about koni's with adjustable ride height then I can't help you. Someone else will probably be along soon though.Mark Link to post Share on other sites
VRmonster 1 Posted May 2, 2005 Report Share Posted May 2, 2005 well the fks come with koni shock inserts so should be the same. (if your refering to damping adjustment) you just remove the parcel shelf and rear panels, to access the strut top, and you have a little flat adjuster, stick your knob on there (ooh errr) and you can turn it between 0 - 720 degrees. start at 360 as thats the middle and stiffen or soften it from there. Link to post Share on other sites
ingham 5 Posted May 3, 2005 Report Share Posted May 3, 2005 if they are not top adjustablethey wil need to be removed Link to post Share on other sites
