vr6turbo 27 Posted April 2, 2013 Report Share Posted April 2, 2013 had a wierd stumbling and missing every now and thenespecially in low gear taking offi have checked for the usual vac leaks plugs coil pack maf vag com is showing 23% load at 650 rpmsound a bit dodgy to me can anyone please confirmthe reading is highand what it might beno faults showing on vagcom ecu diagnostics Link to post Share on other sites
VR6Pete 1,455 Posted April 2, 2013 Report Share Posted April 2, 2013 Which measuring block is showing that figure? Link to post Share on other sites
vr6turbo 27 Posted April 7, 2013 Author Report Share Posted April 7, 2013 group 5 idle control thanks for the replyMonday,01,April,2013,05:20:02:04735VCDS Version: Release 11.11.5Data version: 20121222 Address 01: Engine (021 906 256 )05:19:50 Group 001: General Engine Data 680 /min RPM 88.5°C Coolant Temperature 0.0 % Lambda 5.3 °BTDC Ignition Angle05:19:50 Group 005: Idle Control 680 /min RPM 20.7 % Engine Load THIS IS THE ONE 0.0 km/h Road Speed Idle Operating Mode 05:19:50 Group 006: Fuel Trim 680 /min RPM 0.21 g/s Idling Air Mass Learnt Value 74.5 % Throttle VPOS Duty Cycle Lval. 01 0 AC Compressor Status Link to post Share on other sites
vr6turbo 27 Posted April 13, 2013 Author Report Share Posted April 13, 2013 anyone there? Link to post Share on other sites
Trickygti 3 Posted April 17, 2013 Report Share Posted April 17, 2013 Going off the VAG measured value blocks rather than vagcom ones engine load should be MVB 3 Zone 2 and should be between 1 & 4%Display group 3 -Basic functions- for control unit number: 021906258A ... CKRead measured value block 3 ⇒ [ltrif ] Indicated on displayxxxx rpm x.xx % xx <° xxx.x °C1 2 3 4 [ltrif ] Display zones Specification Evaluation Intake air temperature -45...108.5 °C Throttle valve angle 9...19 <° --- Engine load 1.0...4.0 % --- Engine speed (idling speed) 650...750 rpm Hope that makes a bit of sense, was everything switched off i.e lights, heater, and any other electrical consumers? Link to post Share on other sites
vr6turbo 27 Posted April 18, 2013 Author Report Share Posted April 18, 2013 yes the air con, lights, heater,thanks for the reply Link to post Share on other sites
vr6turbo 27 Posted April 18, 2013 Author Report Share Posted April 18, 2013 dodgy throttle body i have a mate who has one i will give his a try.i cleaned mine out with some good quality solvent we use at work for cleaningso i can rule that out. Link to post Share on other sites
vr6turbo 27 Posted April 28, 2013 Author Report Share Posted April 28, 2013 was the throttle body now running sweet as Link to post Share on other sites
